Carb sync
  • g15usmc
    • Nov 2010
    • 365
    • 29 Palms CA
    Carb sync
    I'm curious whether this is a good carb sync or not...of course if someone else wants it i hope they live in CA, so i can borrow it...LOL but heres the link let me know what you all think... http://cgi.ebay.com/ebaymotors/CARBU...Q5fAccessories
    Daily Driver - '04 Suzuki Marauder 1600
    Project Bike - '79 XS1100 Special
    Hi my name is Nate and I'm am Addict...I quit riding every night before bed and can't help but start riding again the next morning...
    Ride Till You Die!
    "MESS WITH THE BEST DIE LIKE THE REST" -Semper Fidelis!
    “Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.”
    "When in doubt, Gas it!. If it doesnt fix the problem, at least it will end the suspense!"
  • tw1980
    • Apr 2009
    • 662
    • Bend OR
    I think they will work just fine but I would calibrate them before I synced the carbs.Start the bike and hook up each gauge to the same carb one at a time.Adjust the gages so they all read exactly the same,then sync the carbs.
    Terry
    1980 special (Phyllis)
      Terry
      And do that EVERY time before you sync the carbs
      • soccer4m
        • 694
        Get It asap
        Hi G15, I use the same exact model and it works great. No mercury, works at any engine speed and easy to use, just hook up to each vacuum port. A little trick is to use a short 2 x 4 under the front of the gas tank after you lift it up a little and then there is easy access to the synch screws without taking off the tank. SOOO I highly recommend it as I have used it on numerous bikes with good accuracy. But if you really want to ride out to San DIego, you can use mine anytime,,,,,Mike in San DIego
        mike
        1982 xj1100 maxim
        1981 venture bagger
        1999 Kawi Nomad 1500 greenie
        1959 wife
        • g15usmc
          • Nov 2010
          • 365
          • 29 Palms CA
          I know i'm supposed to come down there and have a few beers after i get back from Christmas/New Years vacation in NY, but its getting so hard to wait...then again, they prolly wont come till the day before i leave, Idk if i'll get them or not, but im def. sending a hint to my wife for Christmas, Tools and bikes are my toys...either way If you wouldn't mind i'd still like to bring it down to do it for the first time syncing...
          Ride Till You Die!
            • 1381
            Same ol' Same ol'
            Looks like the exact same set up I own/use but at less than 1/4 the price.
            Note: I connected all the gauges together to one line with tees for calibration purposes. Two of the gauges read differently from the rest.
            Easy fix was to unscrew the plastic faceplate and use the adjusting screw built in to the dial face itself.
            3Phase whimpered about how difficult/glitchy it was to turn the nylon knobs on the individual flow restrictors. To his credit, he removed the nylon needle/screws and lubricated them for me. Now they're flawless. (What a great dude!...)
