oil filter assembly order?
  • KA1J
    • 664
    • Groton, CT
    Hmmm... I can't remember if the spring in the oil filter goes toward the engine block or if it contacts the outer bell housing of the oil filter.
    Yeah, this is one of those "need to know" things...
    Call me dufus...
    Spring in the bottom, washer, then filter.
      • 3193
      • KA1J
        • 664
        • Groton, CT
        Beautiful!
        Should have been that clear in the service manual!
        Thanks for your help!
