Carb Advice?
  • newmaac
    • Dec 2002
    • 369
    • San Jose, CA
    Carb Advice?
    I am just starting the project of breathing new life into a 79F.
    I originally thought that it had been put away "dry". I now find, to no great surprise, that I was wrong, and that the carbs are totally gummed-up.
    Upon dis-assembly, I found one of the needles to be badly worn, and one broken off in the carb body.
    On earlier projects, I was always careful to keep the parts to each carb body together, so that nothing went into a differant body than it came out of.
    In this case though, am I better-off trying to drill-out the broken point of the needle, or using a body off of a bank of carbs from the partzer?
    What do you think?
    Mike
    1980 SG "Angus"
    You might be able to remove the broken-off needle with a simple push pin or a mechanic's pick. Check out the tip in the carb section of the repair section here on the forum pages. If you're just getting into a restoration, you may also want to read over just about everything you can find in the tech tips. There's a lot of stuff there that has been collected over the years. As you come across a little hurdle, chances are it has already been written up....
