Carb removal on the XJ11
  • KA1J
    • 664
    • Groton, CT
    What's the easiest & non destructive way to remove the carbs on an XJ11? The airbox does not look to slide around much. to let me pull off the boots between the airbox & carbs first & then unhook the carbs from the rubber manifolds connected to the head.
    Idears?
    Thanks!
  • wingnut
    • 695
    • NC
    That's the way. Sometimes a hair dryer on the airbox boots to soft them up a bit helps.
    wingnut
    81 SH (Daily Ride)
    81 XS 400
    Thomas Jefferson
    • KA1J
      • 664
      • Groton, CT
      Hair dryer... That's an interesting idea, I'll give it a go!
      Thanks!
      • dirtt1977
        • Jul 2010
        • 2
        • bigfork mt
        Use lots of silicon spray and patience.After the first time carb removal will become a breeze.
        Xs 1100sg. 82 xj 1100
