Seeing as a PO put on a 4-1 exhaust and the air filter is badly needing replaced, I've been trying to decide what to do; it appears to be running lean. If I replace the filter material with a washable material, it'll throw off the jetting even more.
I'm wondering if I were to get the K&N clones and a dynojet 4101 kit set up as stage 3, if that wouldn't be a reasonable way to go as that kit is for the 80-83 XS - XJ1100.
The main questions I'm wondering in this regard are:
If it aspirates and exhausts better I'll expect to get more power but will I get better mileage if I don't change my driving style & keep driving like the geezer in training I already am? I like having all kinds of power but don't really use it that much except sometimes when passing someone when I have to do it quickly.
And...
From the Dynojet page regarding stage 3 jet kits: http://www.dynojet.com/jetkits/index.aspx "Intended for motorcycles with stock or mildly tuned engines using a well designed aftermarket pipe and individual air filters. In most cases power increases of 10-15% can be achieved. However driveability may be compromised particularly with short stroke, high rpm motors. On some modern engine and airbox designs, individual filters and proper jetting offer no performance improvement yet compromise driveability, in such cases stage 3 kits are not available."
So...if anyone's done this with a 80-83 XS - XJ1100, were there any liabilities or negatives you've discovered since making that "stage 3" change?
FWIW, I do have a colortune & Carbtune and am used to using them on the XJ650J so I can adjust & sync as needed.
Thanks!
And...
Thanks!
