80-81 Mixture screw o-rings
    • 3192
    If you are a clutz like me you may lose either the o-rings or the small washer from the mixture screws. I went to the local Yamarobber and they told me these are discontinued. However there is a solution. Suzuki does offer the correct o-rings and washers and they are available individually as well. The O-ring part number is 13295-29900 and the washer part number is 13291-29900. This way one does not have to order the whole mixture screw to get the washer or o-ring. Just thought I would pass this along in case anyone else is in a similar situation. The o-rings were about 5 Canuk bucks and the washers were 2 bucks.
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    You can also get the washer and o-ring from MikesXS, he sells them as a kit with the o-ring, washer and the plug to go over the screw. I didn't use the plug.
      • 3192
      I actually knew that but i was trying to get this bike in a running mode Today, so I tried other avenues as MikesXs in Canada takes a week or so to get here specially if I order friday night...lol. I have several dealers within 15 miles so I did what I could to get it running now. I also ordered enough to repair another set of 80 carbs that I have around. One never knows when he may need a spare set of carbs to try out or loan to someone, or use on another bike. I certainly wish I had the parts a couple of days ago, it would have saved me some time for sure.
