Hitting full throttle with one twist.
    Originally posted by LuckyEddie
    Newbie,
    I came across this on another forum. Check it out:
    A cheap alternative to the R1 throttle tube mod no reason to buy new tubes or grips and it can be installed in about 10 minutes. I just cut a piece of 1" schedule 40 PVC water pipe about 10mm wide and then cut a section out of the ring and it fits right around the throttle tube and is captured inside of the right hand
    Hope this is helpful.
    That's a neat idea, but there is zero extra room inside the housing around the throttle tube on the XS. As mentioned earlier, you'd have to get a new housing with a different tube setup to make that work.
