video of the sports with keihin carbs
  • petejw
    • 2269
    • sydney australia
    heres a vid of my bike with the keihin carbs fitted,
    the mod with the barb didnt work, so the vac adv is disconnected,
    (tho it looks connected in the vid)
    even still the bike runs much better with these carbs,
    its running slightly rich on the video, nothing that a mixture screw
    adj didnt fix,
    btw, the bikes fully warmed up when revving.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
  • yamahansolo
    • Aug 2007
    • 1113
    • jawga
    Awesome sounds like my video!
    So it looks like drilling you mains out close top mine worked.
    I took an old airjet and stuffed it into the vac advance hose. This works well. I found that I have to put it in prime to start when its cold. I never ever used prime if I ride everyday. If it sat then I needed to. While researching zrxoa board it seems like I reaad the big zed uses a fuel pump. Maybe why I need to prime when I start.
    Glad you got it running with those jets!!! This was definatly a great mod!
    79 xs11 standard
    8mm msd wires
    tkat fork brace...
    Fox shocks...
    mikes650 front fender
    led's gallore...
    renthal bars
    gold valve emulators
    vmax tensioner
    Rifle fairing
    • petejw
      • 2269
      • sydney australia
      hey yamahansolo,
      thanx for getting me motivated again
      in trying them out.
      atm im running 140 mains (to big)
      ill be getting 135 mains, the 130 were to lean
      40 pilots,
      i shimmed the needles with 1 washer,
      float levels remained stock
      mixture screws 1 3/4 turns out,
      have u removed the side cover and observed the vac adv
      is urs set at full adv at idle?
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
        I am interested in what you feel the performance improvement is over a properly tuned set of stock carbs. Or do you feel these are just easier to tune?
        I have watched both videos of both of your bikes, and honestly see and hear no difference over the way my bikes run with the stock carbs. But maybe I do not have a tuned ear.
        • TomRodgers
          • Jun 2008
          • 492
          • La Porte Indiana
          Sounds good...but i think it woulda sounded better with your woman friend twisting the throttle from the pilot seat!!!
          '81H (my first XS ) "Grey Ghost"
          4:1 Jardine w/ headerwrap
          Windjammer(wiring issues)
          New paint/brakes to come!!
          '80G FrankenBike (parts bike)
          '80G to fix "BlackSunshine"
          Stock Pilots/125 mains
          Pod filters; 4:1 Kerker??
          SS Brake lines w/ new M/C's
          LED Brake Lite
          Needs paint....
          • Cobia
            • Jul 2007
            • 1587
            • Palm Beach County, Fl
            Hey Pete,
            What kind of can is that you're running. And what brand are those 4x1 pipes?
            1980G Standard, Restored
            Kerker 4 - 1
            850 Rear End Mod
            Automatic CCT
            1980GH Special, Restored
            '82 XJ1100 (Sold)
            • lee_dutcher
              • Apr 2009
              • 822
              • mason city iowa
              i commented on that video and asked the same question cobia
              1980 gs1000g "stock"
              • petejw
                • 2269
                • sydney australia
                Hi Don,
                If your carbs are running sweet and you havent had any
                problems with them, then i wouldnt replace them,
                i spent a small fortune on slide rubbers and springs,
                replaced butterfly seals and have had them apart so many
                times ive lost count, the keihin carbs seem to be more
                responsive, there only a few years old compared to 30 yr old mikunis,
                and ive only spent a cpl of days messing with the
                jets, ill probably add the air box back on which should improve the low end a little more.
                hi Tom,
                hmmm now thats a thought hey
                hi Cobia and Lee,
                not sure of the brand of exhaust it came with the bike and has no markings, but i like it, ill try and take a pic of it, it clears the oil filter housing and allows for the oil cooler, it has a nice wide collector, i need to add a small secondary pipe from the collector to the muffler, i was running a 4-2-1
                tranzac system i didnt like the sound of it, tho it had a good mid range response.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • yamahansolo
                  • Aug 2007
                  • 1113
                  • jawga
                  My stock carbs have 2 broken mixture screw holes... also I get much better mileagewith the new carbs and sotp feel is way better!!! Plus you didn't here it at 7500 rpms going down the road
                  79 xs11 standard
                  8mm msd wires
                  tkat fork brace...
                  Fox shocks...
                  led's gallore...
                  renthal bars
                  vmax tensioner
                  Rifle fairing
