zrx carb update 2.0 41mpg!
  • petejw
    • 2269
    • sydney australia
    #46
    as long as its not pinging,
    you wont go blowing anything up,
    by pinching the vac hose,its a good
    indication that the vac adv is operating correctly
    in that it will hold vacuum.
    instead of pinching the hose, disconnect it
    and plug the vac hose then the vac adv
    will return to its stationary position.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • petejw
      • 2269
      • sydney australia
      #47
      another thing came to mind when i was
      reading your thread, u can bleed the fuel line,
      attach one fuel line to the petcock and turn it on, let the fuel flow
      till u see it just starting to come out the other hose, turn the tap off
      and connect the other hose to the petcock
      this will bleed the fuel line from air, i do this every time
      i reconect my carbs.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
        #48
        Originally posted by yamahansolo
        Well I am happy but I don't want to
        blow something up...
        The only real problem I had was trying to crank it but that was before I realized that the fuel filter was almost empty when I tried to crank. I have to prime it first every time. I never used prime with the stock carbs unless I let it sit for a week.
        My other concern is when I pinch the hose closed it doesn't. Move the advance. It stays all the way to the left.
        I'll check it again tomorrow... thanks for the input.
        What Pete said. In order for it to drop back if the advance unit is good it MUST be open to air. I'll be working on mine this weekend, if I get into the timing cover, I'll try to shoot some video of how the system works, mine is pretty much completely stock so I can show what it should do that way.
        Actually I just looked at Pete's video and that is normal operation there.
        • xsroadrunner
          • Nov 2010
          • 262
          • Southern Comfort
          #49
          Originally posted by petejw
          hi xsroadrunner,
          alanb from the uk site is running the slingshot
          carbs on his bike from memory with really good
          results, try doing a search not sure if he did a write up on,
          but he has on the uk site.
          welcome to the forum btw.
          Thankyou petejw. I am not familiar with the uk site but will look for it. Thanks for the welcome too.
          1982 XJ1100 MadMax-im
          2001 Honda ST1100
            • 8672
            Link to the UK site...
            • xsroadrunner
              • Nov 2010
              • 262
              • Southern Comfort
              #51
              Thanks bikerphil
              2001 Honda ST1100
              • yamahansolo
                • Aug 2007
                • 1113
                • jawga
                #52
                Ok just ran a tank of 87 and I only got 38 mpg...
                I wonder if I get the vac advance working right if it will yield more power?
                79 xs11 standard
                8mm msd wires
                tkat fork brace...
                Fox shocks...
                mikes650 front fender
                led's gallore...
                renthal bars
                gold valve emulators
                vmax tensioner
                Rifle fairing
                • petejw
                  • 2269
                  • sydney australia
                  #53
                  try running it disconnected
                  and see how u go.
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
                  • yamahansolo
                    • Aug 2007
                    • 1113
                    • jawga
                    #54
                    I don't know if you remember the earlier posts I made on this thread but I did run it a week unplugged before I got an airjet to plug up the hole. I didn't notice any difference but I was also running a tank full of sea foam and I got 35 mpg or so.
                    What was it someone said about hooking up the carbs togethher? Where they talking about the ports on the carbs or the little vents on the front side?
                    79 xs11 standard
                    8mm msd wires
                    tkat fork brace...
                    Fox shocks...
                    led's gallore...
                    renthal bars
                    vmax tensioner
                    Rifle fairing
                    • petejw
                      • 2269
                      • sydney australia
                      #55
                      pull the timing cover off on the left side,
                      while u have it hooked up,
                      before u start the engine, look at the location of the vac adv
                      if the vac advances fully while its at idle, disconnect it and block
                      off the intake that it was attached to.
                      what size main jet are u running?
                      i was at 130 but that was a bit lean
                      drilled it out to a 140, now thats a bit on the rich side,
                      im about to run 135 when they get here from nz.
                      im also running 40 pilots, but might drop them down
                      to 38's the nxt time i take em off.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • 81xsproject
                        • 3185
                        • Fortuna, CA
                        #56
                        Probably not, but you might get better economy. When you're deep in the throttle there isn't much vacuum or related advance.
                        '81 XS1100 SH
                        Sep. 12th 2015
                        RIP
                        • petejw
                          • 2269
                          • sydney australia
                          #57
                          like 81 said, the vac adv wont give u more power
                          as such, its more for economy at cruise.
                          what ive done with mine atm, is disconnect the vac adv unit
                          altogether and adv the initial timing.
                          the red marks are for initial timing,
                          i havent put a timing lite on it yet or ridden it,
                          but want to adv the initial timing around a further 5 degrees
                          or until it wont ping under load.
                          also took a video of the vac adv with it connected to a restricted
                          line on the inlet barb, as can be seen, it advances slowly but stays
                          fully advanced at idle, when the engine is killed u can see the vac adv
                          slowly returning to its initial position where it should be at idle.
                          the vac guage is connected to the carb barb that i put in previously
                          and unfortunately doesnt do to much but flutter.
                          pete
                          new owner of
                          08 gen2 hayabusa
                          former owner
                          zrx carbs
                          18mm float height
                          145 main jets
                          38 pilots
