zrx carb update 2.0 41mpg!
  • yamahansolo
    • Aug 2007
    • 1113
    • jawga
    Originally posted by yamahansolo
    79 xs11 standard
    8mm msd wires
    tkat fork brace...
    Fox shocks...
    mikes650 front fender
    led's gallore...
    renthal bars
    gold valve emulators
    vmax tensioner
    Rifle fairing
      That's showing it fully advanced at idle and it retarding when you flick the throttle. This is NOT what the stock setup does. With the stock setup the vacuum advance is fully relaxed at idle, and when you bring engine speed up it will start to pull up, if from there you wack the throttle it will drop back like your video shows and then pull back up when the engine speed gets up to the throttle setting.
      • xsroadrunner
        • Nov 2010
        • 262
        • Southern Comfort
        Fascinating mods you have there video is awesome too Bike sounds great and is real loud. And a beaut of a XS11 too. I have a bank of Suzuki GSXR750 slingshot carbs...wonder if they'll work as well as your ZRX carbs? How difficult a job was it to retrofit the carbs? Did you do a write up of it?
        1982 XJ1100 MadMax-im
        2001 Honda ST1100
        • oldnortonrider
          • 448
          • Fayetteville, ARkansas 72701
          #34
          Yamahansolo~~what he said~~looks to me that it's full counter-clockwise, i.e. advanced at idle, and retards when you're giving it throttle. Wondering if you climb the rpm up slow, if it still wants to move clockwise/retard.............
          (??)....may have to do the "T's" with hook-up to multiple intakes to your advance vacuum line to get a the low retard vacuum pull.......................
          JCarltonRiggs
            #35
            Wouldn't work, it would still be manifold vacuum instead of ported which is what is needed. There should be very little if any vacuum at idle and then just off idle with no load should give max vacuum with vacuum level inversely proportional to load. Except for the no vacuum at idle part that's what he is getting, but the vacuum is not getting shut off at idle like it would with the stock carbs.
            You gotta have that port that gets covered/uncovered with throttle movement. I think that Pete just has the hole a little big and/or just a hair too far forward.
            • yamahansolo
              • Aug 2007
              • 1113
              • jawga
              #36
              Ok maybe I got it backwards but when the bike is off the advancer is sitting in the exact same spot as when its at idle. When I pinched the hose closed all the way the way the vac advance doesn't move. Maybe I'll do anothher vid tomorrow showing this.
              To make sure I am understandin you guys... when the bike is off the vac advance is resting at full throttle? This makes no sense to me. Not trying to argue just trying to understand. Also if this is the case then why is it when I have the choke on the adv. Pulsates until I pinch close the hose going to it.
              79 xs11 standard
              8mm msd wires
              tkat fork brace...
              Fox shocks...
              led's gallore...
              renthal bars
              vmax tensioner
              Rifle fairing
              • petejw
                • 2269
                • sydney australia
                #37
                i took a vid b4 i took off the mikunis off,
                1st vid is of the vac guages
                1st one is connected to the no2 carb barb,
                2nd one is a restricted manifold
                and the 3rd in unrestricted manifold (not relevant)
                2nd vid is of the vac adv
                if you look at the top pick up coil u can see it moving
                yam, i couldnt get ur vid to work,
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                1981 xs1100 RH (aus) (5N5)
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • petejw
                  • 2269
                  • sydney australia
                  #38
                  yam,
                  got your vid to work,
                  looks to me that ur full advance at idle,
                  try disconnecting it and take it out for a ride,
                  what pilots are you running atm?
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
                  • petejw
                    • 2269
                    • sydney australia
                    #39
                    hi xsroadrunner,
                    alanb from the uk site is running the slingshot
                    carbs on his bike from memory with really good
                    results, try doing a search not sure if he did a write up on,
                    but he has on the uk site.
                    welcome to the forum btw.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                    • petejw
                      • 2269
                      • sydney australia
                      #40
                      hey cy,
                      the only other thing i could try is soldering
                      the barb at the butterfly end and redrill with a tiny
                      drill bit, the solder wont stick to the alloy but will
                      to the brass barb, im waiting on sum 135 mains
                      so i wont b pulling the carbs until they arrive,
                      in the mean time i might try adv the initial timing
                      i was thinking around 5 degrees and see how that goes,
                      hey oldnortonrider,
                      ive tried that as well, connected the 4 barbs with 't'
                      pieces, this works well to prevent the pulsating effect,
                      but it still gives manifold vaccuum so it doesnt work either.
                      as i said in another thread,
                      im up for any ideas or theories, thanks guys for chiming in.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • yamahansolo
                        • Aug 2007
                        • 1113
                        • jawga
                        #41
                        Still running 38's. I ran it for a week with it disconnected already.
                        Your below the equator so yours goes in the opposite direction...
                        So at idle the stuff should be all the way to the right? And then it should go to the left when you open the throttle?
                        I am at work and my clymer is at home...
                        79 xs11 standard
                        8mm msd wires
                        tkat fork brace...
                        Fox shocks...
                        led's gallore...
                        renthal bars
                        vmax tensioner
                        Rifle fairing
                        • petejw
                          • 2269
                          • sydney australia
                          #42
                          yam,
                          yeah sort off
                          it should be all the way to the right,
                          under throttle it should stay in the same
                          spot, only under decel or at steady state cruise
                          should the vac advance.
                          hope that make sense,
                          is the video i posted not to clear?
                          try running 40 pilots and see how u go,
                          i still reckon tho that if you connect to
                          the air box itll perform much better whether
                          the vac adv is connected or not.
                          if u jump on the uksite do a search for
                          irish kiwi, he has his set up nicely with an
                          air box and has a good video of how it runs.
                          pete
                          new owner of
                          08 gen2 hayabusa
                          former owner
                          zrx carbs
                          18mm float height
                          145 main jets
                          38 pilots
                          • yamahansolo
                            • Aug 2007
                            • 1113
                            • jawga
                            #43
                            No way jose pods forever!!! They even have xs stamped on them... plus the sound comming out of them is unbeleivable.
                            I have been running it like this for about 2 weeks and I haven't noticed any detonation I'll see if I can get my other 79 to work and run them in the video together. Or I can just pop the old ones on for a bit. Also if its not running right why am I getting gobs of power and 40 mpg?
                            79 xs11 standard
                            8mm msd wires
                            tkat fork brace...
                            Fox shocks...
                            led's gallore...
                            renthal bars
                            vmax tensioner
                            Rifle fairing
                            • petejw
                              • 2269
                              • sydney australia
                              #44
                              lol
                              ive been running pods for years
                              as well, i know where ur coming from,
                              i even get the ringing in the ears afterwards,
                              i just noticed in ur first vid after you reved it
                              it hung for a bit on decel around 1200rpm before
                              it dropped back to idle, but if ur happy with how its
                              running then thats the main thing.
                              pete
                              new owner of
                              08 gen2 hayabusa
                              former owner
                              zrx carbs
                              18mm float height
                              145 main jets
                              38 pilots
                              • yamahansolo
                                • Aug 2007
                                • 1113
                                • jawga
                                #45
                                Well I am happy but I don't want to
                                blow something up...
                                The only real problem I had was trying to crank it but that was before I realized that the fuel filter was almost empty when I tried to crank. I have to prime it first every time. I never used prime with the stock carbs unless I let it sit for a week.
                                My other concern is when I pinch the hose closed it doesn't. Move the advance. It stays all the way to the left.
                                I'll check it again tomorrow... thanks for the input.
                                79 xs11 standard
                                8mm msd wires
                                tkat fork brace...
                                Fox shocks...
                                led's gallore...
                                renthal bars
                                vmax tensioner
                                Rifle fairing
