Hi everyone, I'm in need of some info regarding the speedometer assy on my 1979 special. the existing speedo is pretty much toast. I'm wondering if anyone knows of another unit with which I might replace it as a temporary fix until I find a good 160 mph unit. some of the 120 mph units from other models looks the same I'm just wondering about drive ratios and such. If anyone has a reasonably priced working 160 piece let me know!!!!!thanks, johnny
speedometer
Tags: None
The xs11 has a oddball ratio of 2.9:1 and most aftermarket stock is 2:1. They do make adapters to adjust for that but it is kinda expensive to buy those adapters.Nathan
Theodore Roosevelt -
Any of the speedos from any of the XS's will work, no matter what the MPH range is.1980 XS850SG - Sold
-H. FordComment
to clarify what the 'Bug said, any speedo from any year XS series bike at all, the XS650, XS750, XS850 or the XS11, will work and will read correctly.
So will these guys from MikesXS:-
http://www.mikesxs.net/products-46.html#productsFred Hill, S'toon
"The Flying Pumpkin"Comment
Hi Johnnie and welcome,
Part #03-0729 on my XS1100 and they said they don't have any information on whether it will work on my bike or not.
I believe you guys know what you are talking about, but has anyone actually tried to use one?
Thanks1979 XS1100
1974 CB750
1985 V65 Sabre
1988 KLR650
2001 CR250Comment
I just recieved an email back from mikesxs about using there speedo,
ThanksNathan
Theodore RooseveltComment
Thanks
So don't ask if a particular speedo will work on a XS11; instead, ask if it's calibrated for a 2.9:1 drive or the above 60=2240 number if it doesn't specifically say so. If you don't get a clear answer, it's probably not. The 2:1 units will hook up and work, but will read about 1/3 fast (60 mph actual will show about 80 mph indicated, 90=120, etc).Last edited by crazy steve; 10-28-2010, 08:53 AM.Fast, Cheap, Reliable... Pick any two
while MikesXS don't quote a ratio what the catalog does say is this:-
"Speedometer - Chrome Mini - 2.25" Dia. - Black face, 0-140MPH.
For Yamaha 650's. Internal illumination and Indicator lights.
(High Beam, Signal & Neutral Light). Resettable Tripmeter. "
The other small speedos are quoted the same.
So if it reads right on an XS650 it'll read right on any other XS series bike including the XS11.
Whether those small low-cost speedos will stand up in use or just shake to bits after a few hundred miles, I dunno.
As Nate sez, MikesXS insists that their products are for the XS650 only and denies they'll fit anything else.
Selling mostly into the litigation-crazy USA, who can blame them?Fred Hill, S'toon
Hi everyone, I'm in need of some info regarding the speedometer assy on my 1979 special. the existing speedo is pretty much toast. I'm wondering if anyone knows of another unit with which I might replace it as a temporary fix until I find a good 160 mph unit. some of the 120 mph units from other models looks the same I'm just wondering about drive ratios and such. If anyone has a reasonably priced working 160 piece let me know!!!!!thanks, johnnyUS Army 1986-1991
1979 1100 Special (on the road after 16 years!)
1983 GS300L (wifes ride)
1985 Super Glide
2012 Super GlideComment
Hi Steve,
So if it reads right on an XS650 it'll read right on any other XS series bike including the XS11...
The other thing that makes me question these is I've seen these identical units in many other catalogs, but the listed available ratios don't include 2.9:1. You can get these in 1:1, 2:1, and an oddball 2240:60 ratio, but not the one needed for a Yammy...Fast, Cheap, Reliable... Pick any two
there's been several posts on the XS650 site complaining about the quality of Mikes mini-speedos but nobody said they weren't accurate.
However, I've never used one so I'm just guessing.
My son is going to get a mini-speedo & matching tach (and NOT tell Mike they're for his XS750) to replace his dead stockers. If & when he does, we'll see how they work.Fred Hill, S'toon
Fred, the interesting part is the 'oddball' 2240:60 ratio uses the same numbers as what's listed as calibration on Mikes site (60mph=2240 cable rpm) for the 'replacement' speedos. But 'calibration' and 'ratio' aren't the same thing, or somebody is misusing the term.
I'm not saying these speedos won't fit; they will, as these are made for Harleys primarily and HD got their gauges from Japanese sources, so the cable connections are pretty much the same. But a speedo that's off by 1/3 isn't overly useful IMO....
If your kid buys a set of these, for sure run it through a measured mile and see what he gets; then we'll know...Fast, Cheap, Reliable... Pick any two
