XS11 Venture Fork Springs
  • rpgoerlich
    • Dec 2007
    • 643
    • Katy, Tx
    So the last few weeks I've been riding the Venture to and from work. I've put 750mi on it since I got it. It had sat outside since 1988 until I got a year ago. I replaced the fork seals after the final rebuild with 20w fork oil, no spring spacer. I added 10psi in the forks. Running 28psi on the front tire.
    I've noticed that even with the 10psi the forks drop 2¼" once off the center stand and another 1" with me on it. Which makes it seem like I'm leaning forward. I've tried adding more pressure but it makes for a rough ride.
    I've been thinking about adding a spring spacer(I think springs may be wore out though) or getting a set of progressive springs for it. Before I do, I was curious what ya'll are running on standards with front fairings. What kind of springs, spacers, fork oil pressure, tire pressure?
    Thanks,
    Richard
    Hi Richard,
    You may be right the springs are worn out. regret I have never measured mine so can not compare for you. Mine definitely does not settle 2 1/2 inches off the stand though it may drop the 1 inch with my fat arse on it
    I have 15 w oil in mine and it dives a lot when braking. No air as yet which should help. Sure soaks up the bumps on the highway the way mine is set up. I run 38psi in the front tire as my Dunlop felt mushy at lower pressure.
      I would spend the $75 or so on new progressive springs. My '79 has the new springs, and it does NOT settle as much as yours. I would also run a little more pressure in the front tire with a fairing, just because.....
        Don't forget, the way these seem to be designed, they use a lot of travel. Cheap way to fix is with a spacer, maybe 1/4 or 1/2 inch. PVC pipe works well. The cap threads strip easily so be careful.
        • rpgoerlich
          • Dec 2007
          • 643
          • Katy, Tx
          I agree with alot of travel. Today I came within an inch or two of the lower triple tree running some back county roads. This is with the T-Kat fork brace on top of the fork lowers.
          I came back and bumped pressure up to 20psi. Went for a 70mi ride with a few twisties. Handled ok... but a bit stiff.
          Going to pull the caps this week and install a ½" cpvc coupling as a spacer.
          Will see how it performs with no pressure first.
          Richard
          • RS Thornton
            • Jul 2003
            • 343
            • Spring, Texas
            on the 78E
            running progressive springs on the 2nd of the 3 preload settings. Worked my way up through 15 to 20 and now finally to 30W fork oil. I have the TKAT brace on there as well. I have one of those very heavy Pacifico fairings and with this set up bike has handled gravel, twisties and Interstates. I cannot say that I noticed much difference between the 20 and 30W, but the progressive springs and the fork brace make a huge difference in handling.
            I have a bike and I am not afraid to use it
            • rpgoerlich
              • Dec 2007
              • 643
              • Katy, Tx
              Had some time yesterday after everyone passed out from the turkey .
              Iinstalled ¾" pvc for a spring spacer as that was all I could push in and still get the fork cap screwed in.
              Seems to have helped the ride and without the air. I was only able to get out for 5miles before I got caught in a downpour. Drops roughly an inch when sat on and still has plenty of travel. Will know more after I get a few more rides in to and from work next week.
              Richard
