screw on oil filter kit
  • OLY-XSer
    • Jun 2010
    • 46
    • Olympia, WA
    A while back i saw a screw on oil filter kit for the xs11 for about 60 bucks. problem is i can't remember what site i saw it on. has anyone else seen this and what site is it. thanks for the help.
    1980 xs11sg
    16600 miles, soon to be a lot more
    stock headers with free flow exhaust
    mikes xs pods
    #45 pilot jets
    #130 main jets on 2 & 3
    #125 main jets on 1 & 4
    That would probably be here...
    Here's a thread on the SOFA (Spin On Filter Adaptor): http://www.xs11.com/forum/showthread...highlight=SOFA
    Contact member TopCatGR58 for pricing/availability.
    • mxmikie
      • Aug 2008
      • 482
      • Bouse az
      i think i have one for $40.00
        There is also a version from topcat that allows for an oil cooler.
        • XS1100 Newbie
          • Jun 2009
          • 1106
          • Battle Ground, Washington
          I have one i have not used. It is still packaged. It is the SOFA only.
          1980 XS1100LG Midnight
          1991 Honda CBR1000F Hurricane
          A cold beer and another one!
          • mxmikie
            • Aug 2008
            • 482
            • Bouse az
            the xj600 one works
            • cywelchjr
              XS-XJ Super Guru(Deceased)
              • 4450
              • Sacramento, CA
              I just got one from TC and I'm impressed with the workmanship. Gotta get a filter for it and high temp etching primer and paint and get it painted and then on it goes with the next oil change. Among other things I expect that it will make oil changes less messy, and with as many goldwings as there are out there I expect the filter for it will be around for a long time.
                I have one of the older versions of his SOFCA and I am having a heck of a time finding a filter that works without bottoming out on the nut. I am constantly leaking oil because of the problem. I think TC has changed them to account for this problem (I think he made the hole for the nut larger so that you do not need the washer and then the nut sits way lower). I am going to have to widen out the hole so I can ditch the washer.
                So as a heads up be careful about buying these from other members because you may have to deal with this problem.
                • XS1100 Newbie
                  • Jun 2009
                  • 1106
                  You could be right Nathan. Seems like i remember something like that. Mine was purchased middle of this year, so if there was a correction made, mine probably has it. I think a note to TC might be appropriate for him to make sure.
