Removing Gererator Cover
  • rickybeaver
    • Sep 2010
    • 25
    I am going to replace the generator cover on my xs1100 do I have to replace the electrical parts inside or can I just replace the cover. I see there are three allen heads in the middle and some around the perimeter. Do I have to remove them all? Also is there a gasket that should be replaced also? Thanks:Rick
    Having a ball with this old thing,seem to be riding it more than my V-Star.
    1980 XS 1100 replaced the seat and sissy bar from a XS 1100 standard and changed the handle bars. Did not like the original bars at all.No mod at all except for a four into one header.
    Don't take the 3 center Allen bolts out, or you will have to re-align the stator assembly. If it isn't centered perfectly, the rotor can hit the stator and ruin it. There should be a gasket between the cover and the engine case. If you don't have a good one, either make one out of gasket paper or perhaps just use RTV. You don't want any rain water getting up in there. Also, there is a taper fit oil galley plug at the bottom of the engine case. If it was leaking oil, you might want to pull that out and replace the O-ring with a new one. Do not by any means run or turn the engine with the alt cover off, as the oil pressure will blow that plug out and spew oil everywhere. The only thing holding that plug in is the tightened down alt cover. Just replace the whole assembly and don't remove the internal stator if all possible. HTH
      Hi Ricky,
      the cover is just an aluminum casting but the inner and outer alternator coils are attached to it.
      The 3 inner bolts hold the inner coil to the casting and are best left in place until the cover is off the engine block.
      Why you do that BTW?
        If the cover just doesn't look food just spends a little time cleaning and polishing it.
        • cywelchjr
          XS-XJ Super Guru(Deceased)
          • 4450
          • Sacramento, CA
          My cover doesn't look food, but if it did I would get hungry when riding.
          • OregonRider
            • Jun 2010
            • 33
            Really dumb question
            before I go removing covers and cause more problems...
            Is the generator on the left or right side on an XJ1100?
            I know the left side is the Timing Plate cover. So here is the reason for my question, I have a service manual that highlights various parts of the bike and labels it R.H. or L.H. It points to the Timing Plate cover with L.H. Which doesn't make sense to me. Is the generator behind the timing plate? I don't think so...
            I'm assuming the Generator cover is actually on the right side (large round cover near the highway pegs, inline with the crank shaft and has 5 screws holding it on.
            Last time I thought I knew what I was doing without being sure was on an old Honda CB400 and made a real mess on my garage floor.
            "Good decisions are usually the result of the cumulative consequences of bad decisions."
            82' XJ1100 turned "bagger" with Vetter Fairing.
              Right side in line with the crank as you are sitting on the bike. Don't run the bike with the cover off, there is an oil galley plug that will fly out when oil pressure is obtained.
              • tom clisham
                • Sep 2010
                • 627
                • Northern Illinois
                It's definitely on the right side.
                I've got to replace mine due to damage on the bottom, & figured I'd use the old coils, etc. Hope nothing goes wrong
                Tom Clisham
                Age is relative YOU WON"T GET OLD TIL YOU SELL THE BIKE
                _____________________________________________
                '78xs1100E ,all stock & original GONE TO WISCONSIN
                '80 SG Vetter fairing,hard bags,trunk,fork brace,
                stock headers with fishtail mufflers,black & beautiful GONE TO ARIZONA
                79SF lowered,jardine 4/2 exhaust,pod filters,drilled rotors,fork brace, bar hopper
                79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
                • OregonRider
                  • Jun 2010
                  • 33
                  Awesome, Thanks guy's.
                  I want to check the brushes. bought a set on e-bay a while back but just now getting to it.
                  • James England
                    • 3039
                    • North of England
                    What brushes?
                    • foreda
                      • 949
                      • Southwest Louisiana
                      Brushes
                      Like James said.. What brushes??
                      78 XS1100E Standard
                      Coca Cola Red
                      Hooker Headers
                      1979 XS1100 Special
                      1980 XS Standard
                      2006 Roadstar Warrior
                      • lancelot455
                        • Sep 2010
                        • 174
                        • Regina,Saskatchewan,Canada
                        It's an XJ they have brushes inside that need replacing.
                        82 XJ1100
                        Canada
                        2006 V-Star 1100 custom
                        • foreda
                          • 949
                          Brushes
                          Hmm. Learn something everyday! Seems odd though!
                          I don't know didley about XJ's.
                          78 XS1100E Standard
                          Coca Cola Red
                          Hooker Headers
                          1979 XS1100 Special
                          1980 XS Standard
                          • cywelchjr
                            • 4450
                            • Sacramento, CA
                            Xj's have a different system with brushes that puts out a little more juice. The price is the brushes that must be replaced every so often.
                            • James England
                              • 3039
                              • North of England
                              I read this and didn't realise the thread had metamorphosed into an XJ. I now retract my question "what brushes?" ! I'm kind of pleased the XS doesn't have them...
