Older style carbs
    Older style carbs
    Working on my first set of the 78-79 version of the carbs. How can I tell if it is a 78 or 79 setup? Did they use different needle jets or emulsion tubes from 78 to 79?
    The air, pilot, and mains are not right at all. look to eb aftermarket and 40 pilots with 130 mains, and 180 pilot air jets. So I am trying to figure if I should jet with 42.5 or 45 pilot jets. Plan is to clean them up and get them setup and ready to run, then send to a new owner yet to be named or determined. They have the plastic floats, so going with the XV920 float valves. So I could go either way, but if the needle and emulsion tubes determine a setup, that is the way I want to go with it.
  • petejw
    • 2269
    • sydney australia
    hey dgxser,
    heres a good link from the uk site with carb specs
    for all the models.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
      Didn't the 79 have 180 air jets? 78 had 210.
      • geobiker
        • Mar 2010
        • 82
        • Pa
        Carbs
        DGXSER:
        According to my Clymer Manual, the 78E and 78F had the same main jet (137.5), the same needle jet or emulsion tube (X-2), same pilot jet (42.5) and same air pilot jet (180). The jet needle is a 5GZ6.
        Don't know if this helps.
        Geobiker
        1979 F
        Mac 4-2 Exhaust
        T-Kat Fork Brace
        Spade Fuse Box Mod
        Stainless Steel Braided Brake Lines
        140.0 Main Jets
        45.0 Pilot Jets
        266 X-2 Needle Jets
          • 5062
          Originally posted by DGXSER
          The air, pilot, and mains are not right at all. look to eb aftermarket and 40 pilots with 130 mains, and 180 pilot air jets. So I am trying to figure if I should jet with 42.5 or 45 pilot jets. .
          Maybe the pilots were downsized to compensate for being the wrong type and resulting previous probs with being too rich? The right type has a small oriface at the upper end (as installed). I never owned a 79, but the 78 does have 210 air's.
            Originally posted by geobiker
            DGXSER:
            Geobiker
            this is one of those situations where the clymer manual is wrong.
              • 8796
              If you follow the Clymers recommendation for the 79, you should be good. This would be for a stock setup, of course.
              pilot jets 42.5/180
              main: 137.5
              float level 25.7mm
              The 210 air jet setup is for the 78 and very early 79 models with the hot cams. IIRC, they also used a 45 pilot.
                Even the factory manual is wrong; my '78 FSM calls out a 180 pilot, but my unmolested-since-new carbs had 210s in 'em...
                • 81xsproject
                  • 3185
                  • Fortuna, CA
                  The only difference I know of is that the 78 has a larger Starter Jet size in the bowl. But, this won't help identify one from the other. On a more positive note, it doesn't matter which is which because everything else is the same.
                  '81 XS1100 SH
                  Sep. 12th 2015
                  RIP
                  • yamahansolo
                    • Aug 2007
                    • 1113
                    • jawga
                    My 79 made in april 78 came with 140 mains 45 pilots and 210 airjets. There are a few older posts about this. I don't think the 78's were 210 air though. If you look at some of the parts fische you will see two different jettings for 79 search for one of my previous threads
                    79 xs11 standard
                    8mm msd wires
                    tkat fork brace...
                    Fox shocks...
                    mikes650 front fender
                    led's gallore...
                    renthal bars
                    gold valve emulators
                    vmax tensioner
                    Rifle fairing
                      Looking over all the great input, gives me plenty to think on. Most likely go with the 42.5 pilots, looks like they have the correct pilot air jets for that and get new mains the right size. Especially since my test bike is the 81 model, (have to test them before I'd send them to a new home) it might run like crap on those large pilots and air jets with the milder set up.
                      Thanks for all the great input!
                        • 8796
                        Also, needle clips should be in the 3rd (center) position.
