Charging problem
  • tri650
    • Feb 2010
    • 89
    • St. Louis, MO
    Charging problem
    On my 78 XS11 I keep losing my battery as it is not charging. I get about 80 miles before it is dead.
    I tried the rev test and the voltmeter did not move. I put in a new stator/coil from a donor bike as well as a voltage regulator. Still can't get the charge to change as I rev the motor. Checked all connections - I think I got all of the important ones. What am I missing?
    _____________________
    78 XS1100 - mainly stock
    The biggest ones to check are the ones behind the fuse panel, between it and the battery box.
      • 8891
      As a test, you can try tapping into the dark green field coil wire and connect to ground. Check again with a volt meter at the battery and see if it is charging. Make sure the ground connection at the regulator is solid and the ones mentioned above are clean first though.
      • old_chopper
        • Sep 2010
        • 120
        • Oklahoma
        Just fought this same battle. Make sure you have 12vdc with the key on at the brown wire going to the stator/field coil. If so check the right side case to see if there is any magnestism from the fields. A thin feeler gage works great for this. If yes and yes start the bike and unplug the connector with 3 or 4 wires coming out of the stator. Check across any two of the same color to see if you have 10-30 vac. If so then the stator is working and the regulator is suspect.
        Hope this helps.
        US Army 1986-1991
        1979 1100 Special (on the road after 16 years!)
        1983 GS300L (wifes ride)
        1985 Super Glide
        2012 Super Glide
        • Incubus
          • 1003
          • Austin TX
          Does your tach work?
          Patrick
          XS11F (Incubus, daily rider)
          1969 Yamaha DT1B
          • tri650
            • Feb 2010
            • 89
            • St. Louis, MO
            No - tach does not work. And that started when I started having charging problems.
            • Incubus
              • 1003
              • Austin TX
              That points to the vreg.
              1969 Yamaha DT1B
              • tri650
                • Feb 2010
                • 89
                • St. Louis, MO
                I took the one off of the donor bike and replaced the old one - of course that assumes the donor bike vreg was good. How do I test this?
                • Incubus
                  • 1003
                  • Austin TX
                  Put it on, start the bike and measure the voltage across the battery. If, when you start it up, the tach starts working - that's a good sign. But you still have to measure the voltage. I've had a vreg go bad and overcharge rather than undercharge.
                  Patrick
                  1969 Yamaha DT1B
                  • tri650
                    • Feb 2010
                    • 89
                    • St. Louis, MO
                    Thanks - I will check that out tonight. I recall the tach was not working at all - even from the start. It was working previously before I had the electrical problems.
                    Also, since I went through all of this I lost my neutral light and turn signal lights - any relationship to everything else going on?
                    • Incubus
                      • 1003
                      • Austin TX
                      No, those are unrelated systems. The turn signals will light and not flash if the bike isn't charging and the battery is low, but if they aren't lighting at all then I'd check the fuse. The neutral light is just one wire. It runs from the switch in the bottom of the case. When the bike is in neutral the circuit is complete (the switch on the case completes the ground). When the bike is in gear the circuit is not complete. Should be pretty easy to trace.
                      Patrick
                      1969 Yamaha DT1B
