OEM fuel hose
    OEM fuel hose
    What is it and where do I get it. What's available to me locally has a much larger OD and will require all new clamps. I would prefer to avoid that. I like spring clamps in this application.
    A lot of people say to order some 3/8 tygon line and then its tight enough to not use clamps.
    • Mr.Bill
      • Aug 2009
      • 118
      • Clarksburg Maryland
      I think you meant 3/16" not 3/8" which would be larger then 1/4"
      3/16" tygon tubing.
      1979 XS1100SF.
      "You know what makes me sad... YOU DO, Why dont we run over to mamby pamby land and get you some self confidence you jack wagon" Will go down as one of the great quotes LOL
      • Tropic-al
        • Nov 2009
        • 176
        • Tampa, Florida
        Fuel line.
        Tygon is a little expensive but a real good hose.
        In my experience even with dirt bikes, a zip tie held with pliers and pushed to close tight with long nosed pliers works better than the spring clamps.
        79 XS1100F.
        TC's fuse box.
        SOFA filter.
        Venture cam chain adjuster.
        Tkat fork brace.
        Progressive fork springs.
        • Incubus
          • 1003
          • Austin TX
          OI use 1/4-inch ID thin walled fuel line that they sell at my local MC shops for about $1 a foot. Car parts suppliers don't sell it, at least not around here. I use spring clamps on it that I also get from them.
          Patrick
          XS11F (Incubus, daily rider)
          1969 Yamaha DT1B
            Like others here, I have used the stuff from the local MC shop. I also used to be able to get the Briggs and Stratton yellow fuel line at my local chain hardware store (now they went even cheaper and that crap sucks). I ran for two years with the B&S fuel line on Thunderstruck, no problems at all.
            You probably already know this, but I advise against the automotive fuel line with the hard outer liner and the softer inner rubber. I tried that for a while and it drove me insane because the soft inner rubber would chaffe off pieces everytime I hooked ti to the fuel Ts in the carbs. Those pieces would clog my float valves and they would leak! Finally figured it out and went to the B&S line and never had leak issues again....well....not on the bike anyway.
              Hi Marty,
              there's always MikesXS
              http://www.mikesxs.net/products-34.html#products
              Item #20-4010. 1/4" bore thinwall x 11.5" long at $1 each.
                Ah yes, Mike's XS. I have hopes of finding some locally, because every mail order sets me back a month. That's because my job has me away three weeks at a time. At least, Mike's is very fast.
                  Yes 3/16 is what I meant but not what came out sorry.
                    +1 to the tygon stuff. I buy mine at O'reilly for just over $2/foot. Works great, and stays flexible, plus you can see through it for checking fuel levels in the float bowls.
                    • Deathdeelr
                      • Mar 2010
                      • 35
                      • Sussex, NJ
                      Patrick
                      I use this stuff with Tropic-al's zip tie clamps. Works good so long as you don't kink it. I changed the hose routing as per other posts so the left side now feeds #3 & 4 and the right side feeds #1 & 2. This allows a long enough loop to prevent the kink and I can run small filters.
                      Me Make Big Dings Wid Hamma N Welda
                      1985 VMX1200
