Cam Chain Life span?
  • Rickrod3
    • Jun 2009
    • 721
    • Oakland, New Jersey
    Currently tring to unstick an engine. I know I'm going to have to pull the head to decarbonize the top end. If I free it I can save the cam chain. Unless it was replaced which I doubt has 43K on it.
    How long do they last?
    TIA
    Rick
    650SF
    XS1100SG Project bike
  • SFerinTEXAS
    • Jun 2006
    • 877
    If you are not going after ring problems, There are several ways to deal with carbon issues w/o pulling the head. Last choice for me anyway. Cam chain is good for 100kplus
    79SF
    XJ11
    78E
    • subike
      • 167
      • Christchurch New Zealand
      My 1980 std has done 373k miles since new,
      I am its 2nd owner. ( 1 yr now)
      in that time it has only ever been service and had 2 clutch pacs.
      The PO was fastidious in his maintenance
      Except for a after market exhaust, every thing is stock.
      So 373k miles for the cam chain. I think you could call that relyable eh.
      Mind you the PO never thrashed the bike either.
      http://i139.photobucket.com/albums/q...e/DSC00009.jpg
      1980 XS1100 Std English Assembled, 378k miles
      In stock untouched contion.
      http://i139.photobucket.com/albums/q...e/seatside.jpg
      1979 XS1100F Std NZ new,
      Mikes XS coils
      Jardine 4-1
      Pod filters
      Harley Davidson Rear Fender
      Bullet signal lights
      Twin 75mm headlights
      Self made single seat
        • 8893
        When you have yout CCT out, look at the bolt marks on the plunger shaft. This will give you an idea of how much adjustment is left. Once you run out of adjustment, the chain needs replacing. The Venture CCT mod will give you some extra life on the chain because the plunger extends further than the stock unit. Remember, the more slack (wear) in the chain, the further the cams get out of time. A new chain will "pep" up the motor.
