Voltage Regulator
  • LuckyEddie
    • 166
    • Middleville, Michigan
    Voltage Regulator
    Greetings,
    I came across this in my search for other parts. It may be useful to others.
    Here is a link: http://www.dbelectrical.com/p-6031-n...c-aya6008.aspx
    LuckyEddie
    1980 XS1100LG Midnight special
    1982 XV750J Virago
    1976 GL1000
    1978 GL1000 Supercharged
    1981 XV920RH (chain drive)
  • rover
    • Jan 2004
    • 765
    • central WI (715)
    regulator
    Geezer makes and sells a much improved voltage regulator, plus he will answer questions and even sell the correct connectors. This regulator gives full charge at a lower RPM than the OEM.
    79 F (Blueballs)
    79 SF (Redbutt)
    81 LH (organ donor)
    76 CB 750 (gone to MC heaven)
    rover has spoken
      Decent price for new!
        Yeah, but geezer has a LIFETIME warranty on his part, and it WILL charge at full voltage at 1,500RPM, NOT 2,500RPM like stock. Yes, it will cost a little more, but , "you can go cheap, or you can pay more for quality".
          Oh o totally agree, if and when I need one i am buying one from geezer, even if I can get a nos one for 10 bucks
          • b.walker5
            • Feb 2009
            • 1745
            • Invercargill, New Zealand
            Check here http://www.electrosport.com/technica...g-system-works for a very good description of charging systems and regulators. Ours (XS) is covered near the bottom of the article but for the adventurous it's also show that a standard three phase rectifier http://www.alliedelec.com/search/pro...0575#tab=Specs and a simple Bosch RE55 regulator http://www.naauto.biz/catalogue/cate...y39/product364 available for peanuts from most all auto electric suppliers will do the trick if your stuck.
            I ran an XS750 with this setup for quite a while, until I tracked down an OEM, and it worked fine.
