Another service item
  • planedick
    • Mar 2005
    • 2068
    • Yorba Linda, California
    I have found that the odometer quits because the worm gears wear out. The fix is to remove the plastic housing for the contact switch for the self canceling signals and the gears are fight there. A little grease applied there with a tooth pick or similar will make 'em last and last. I suppose every year would make them last forever.....
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
    • 8074
    I put white lithium grease on mine. I do it just as you stated.
