Different jets?
  • Tropic-al
    • Nov 2009
    • 173
    • Tampa, Florida
    Different jets?
    Did my first carb clean today. Everything came out great, got cleaned up and reassembled. Pilots were clogged up but amazingly did not have lots of crud/varnish in the bowls. Have not installed yet.
    While checking, I came up with 137.5 main jet, 45 pilot jet and 210 pilot air.
    Supposedly stock pilot jet should be 42.5 and 180 for pilot air.
    PO had a Kerker 4 into 1 when I bought the bike in 1983 with 7,000 miles. He must have swapped jets for the Kerker.
    Later I put a Super Trapp 4 into 1. Bike has always started easy almost no choke, idles great at about 1000 rpm's. I mostly just cruise and in hway do about 75, 80 mph.
    What effect good or bad can this cause.
    79 XS1100F.
    TC's fuse box.
    SOFA filter.
    Venture cam chain adjuster.
    Tkat fork brace.
    Progressive fork springs.
    Those are the stock jets for a 78.
      The jets really effect the fuel mixture. If you feel the bike is running good and the plugs show it is running good with the jets you have, then like the old saying goes, if it ain't broke, don't fix it!!
      Your Supertrap may be different than the Kerker, but it is still not stock. And if your running POD filters instead of the factory air box, that to will effect the jetting required. I'd say you did not change the system enough swapping the Kerker to the Supertrap to change the jetting required.
        • 8736
        Something I just recently learned is that the first 100 79F's produced were set up like the 78E, with different jetting and hot cams. If you have a very early 79F, this might be the case with the pilot jetting of 45/210.
        • yamahansolo
          • Aug 2007
          • 1113
          • jawga
          It was 500... mine is 491. The 78 was 137.5 my 79 ha 140 mains 45 pilots and 210 air jets. These are on some of the parts fische
          79 xs11 standard
          8mm msd wires
          tkat fork brace...
          Fox shocks...
          mikes650 front fender
          led's gallore...
          renthal bars
          gold valve emulators
          vmax tensioner
          Rifle fairing
