I took the speedometer apart on my XS this evening. I didn't do a very good job but I learned a bit and got the mechanism cleaned up and working. This is one of the round 160 mph models and I want to save it. Can I pick up an easy to find 85 moh model and put my mechanism in it? I need a new front bezel that crimps over the plastic cup the most. I had a tough time uncrimping it. Also need a needle.
Speed-o-meter repair
US Army 1986-1991
1979 1100 Special (on the road after 16 years!)
1983 GS300L (wifes ride)
1985 Super Glide
2012 Super GlideTags: None -
Those front bezels are not sold separately. They are just about impossible to remove without damaging, so most people just replace their speedo instead of trying to open it up. If I were you, I would find a replacement speedo and call it done.1980 XS850SG - Sold
-H. Ford -
the speedo guts should swap no problem. I'm not too proud to learn from the younger generation; if the speedo needle is still on the pin but bust off short, my son Eric fixed his by epoxying the proper length of red plastic spray tube from a rattlecan onto the stub.Fred Hill, S'toon
"The Flying Pumpkin"Comment
You can try 'recalibrating' by messing with the needle spring adjustment, but it didn't work for me; I ended up replacing.Fast, Cheap, Reliable... Pick any two
I don't know much about speedo's i would never be caught in one personally..
but foolishness aside.
I'm not sure if this will help but it's what i needed at the time.
speedometer breakdown and lube.pdf
Good Luck1979 XS1100SF Special.78 E motor/carbs, Jardine 4-2 exhaust, XS Green coils, Corbin seat, S.S. Brake lines, Hard cases, Heated grips.
Most bike problems are caused by a loose nut connecting the handlebars and the seat!!Comment
