Leaking rear brake MC?
  • QTreiber
    • Oct 2009
    • 46
    • Westminster, CO
    Hello,
    I am the happy (relatively new) owner of an 1979 XS 1100, a transplant from another forum member in SoCal:
    I love the bike and enjoy taking it to the hills here in Colorado, runs great even on dirt roads.
    Time to introduce myself and start asking questions...
    I noticed that the lower part of the rear brake master cylinder looks wet.
    Do I have to rebuild it?
    Thanks in advance for any advice and greetings from the Front Range,
    Armin
    2018 Suzuki DR650, no XS1100 right now.
    Probably wouldn't be a bad idea rebuilding the rear MC....
    http://store03.prostores.com/servlet...-XS1100/Detail
      Could wait till winter probably. Then you could pull it apart and see what it looks like and then decide is you need the kit or not.
      Have fun bleeding that SOB.
        If it were my bike, next wet weekend, I'd pull it off, open it up and clean the inside and components really well. Reassemble and have the pleasure of bleeding it out. Then see if the problem persist. If it does, then order the rebuild parts.
        Nothing wrong with rebuilding the first time if you rather get it fixed once and be done. More I think of it and the PITA it is to bleed that rear mc, I'd probably go that route. But, cleaning them up will do the trick most of the time.
        • TomRodgers
          • Jun 2008
          • 492
          • La Porte Indiana
          +1 on the above...
          Even with limited knowledge, pulling the rear m/c and components off, cleaning them, and reinstalling is about a 3 beer project...maybe 4 beers
          never take 2nd chances with brakes!!! There arent too many things in life as scary as tooling around on a bike at 30 or 40 + mph, hit the brakes and no friction!!!
          '81H (my first XS ) "Grey Ghost"
          4:1 Jardine w/ headerwrap
          Windjammer(wiring issues)
          New paint/brakes to come!!
          '80G FrankenBike (parts bike)
          '80G to fix "BlackSunshine"
          Stock Pilots/125 mains
          Pod filters; 4:1 Kerker??
          SS Brake lines w/ new M/C's
          LED Brake Lite
          Needs paint....
          • QTreiber
            • Oct 2009
            • 46
            • Westminster, CO
            Thanks for all the great advice! I ordered the rebuild kit. This is a first to me so I will research some posts here on rebuilding and bleeding, which seems to be a bit of a challenge.
            Can someone please explain how cleaning the MC could actually fix the problem? How does debris lead to leaking? By clogging pathways?
            Looking forward to get this done!
            Greetings from Colorado,
            Armin
              If a piece of dirt or debris got stuck under a seal when the piston slid in or out it could cause a leak.
              The biggest issue with bleeding is the crazy way the MC sits below the caliper. So gravity tends to work against you and cause air bubbles. Very hard to pull fluid. I have resorted to the Mity Vac for it.
                • 3193
                This is an extreme example but kind of shows you how far that debris can go. Like DGXSER says it can cause leaks. I have not had any problem so far as bleeding my rear M/C's but the fronts have caused me no end of grief.
                  Holy crap rasputin! Did you actually get that clean or did you replace that?
                  • geobiker
                    • Mar 2010
                    • 82
                    • Pa
                    Gnarly
                    Without doubt, that is the rattiest looking master cylinder that I have seen! I'm just wondering how many years that it took the brake fluid to congeal like that!
                    1979 F
                    Mac 4-2 Exhaust
                    T-Kat Fork Brace
                    Spade Fuse Box Mod
                    Stainless Steel Braided Brake Lines
                    140.0 Main Jets
                    45.0 Pilot Jets
                    266 X-2 Needle Jets
                      • 3193
                      I got it cleaned out and it works fine. I do have a rebuild kit that will be going in to be on the safe side though. It does not take all that long to congeal like that either as this particular one seems to have had a mix of DOT3 and DOT5 fluids in it. Stirred in a bit of DOT3 and it went back to fluid form. Left it a few weeks and it was back to the same as in the pic. Do Not Mix different types of brake fluids like this PO did .
                      • QTreiber
                        • Oct 2009
                        • 46
                        • Westminster, CO
                        Success!
                        Well, I took - with the help of a very capable local forum member - the rear MC apart.
                        Things did not look quite as bad as the pictures above, but there was some debris and corrosion:
                        Cleaned everything, installed new piston, bled the system. The inner surface of the cylinder is not perfect, but pretty smooth after gentle polishing.
                        So far no leaks and the break seems to grab stronger - success!
                        Thanks again for all your help,
                        Armin
                          Congrats on a job well done! Now go brake something!!
