I am sure that someone has added an HID headlight to thier XS. I am wanting to upgrade the lights on mine as well. Any suggestions on where to get a kit or how complex it is to install?
HID kits
They are basically all about the same, the ballast unit takes up a bit of room and is easiest to use if you have a fairing to hide it in. You will also need to eliminate and bypass your reserve lighting unit as it will no longer be able to find a light filament to test and so will constantly switch from high to low beam trying to remedy a problem that is not there. Most of them also need more room in the back of the headlight reflector than is currently allowed for. This is usually easily done but I have heard of some units that require more room than is there.
Mine needed a bit of work with the zip saw to make enough room behind the headlight bucket on my Vetter V. Also keep in mind that some of the units out there use an H4 or similar type bulb for the low beam and the HID for the high beam, stay away from them. The best types have a solenoid unit right in the bulb that gives you high/low by actually moving the filament inside the bulb itself, I have found these to be far superior.
The one I have is a newcomdigi and it is like looking at an arc light even in the daytime. At night it will carve an almost mile long tunnel of light through the darkness and is well worth any trouble you may have installing it.The Old Tamer
_________________________
1979 XS1100SF (The Fire Dragon)
1982 650 Maxim (The Little Dragon)
another '82 650 Maxim (Parts Dragon)
1981 XS1100SH (The Black Dragon)
If there are more than three bolts holding it on there, it is most likely a very important part! -
I absolutely LOVE mine!
H4 bi-zenon is the way to go (HID on both hi and low by using a solenoid to shift the bulb in the housing from high to low). You should also look at getting one with the slimline ballast. That ballast is small enough that you can mount it right in front of the regulator/rectifier under the tank. The wiring worked out perfectly for me.-- Clint
1979 XS1100F - bought for $500 in 1989Comment
Anyone ever stuck one in a special headlight bucket?Nathan
Theodore RooseveltComment
My HID went into a Pacifico fairing with no trouble at all. Some eBay sellers are offering a "modular" kit, with just enough wiring in plug in sections for what you need. The kit I got has a long and a short pigtail for two lights, but I just got one light. Plenty of room in the fairing for the extra wiring, but it'd be a nuisance on a naked bike. But yes, the light is wonderful. Don't know if mine will go a mile, but it does as good as 2 halogens on my truck.1980 XS 11 Special: The King of Kong, 9th wonder of the world. Pacifico fairing, chopped shield, Yamaha hard bags, Diamond seat, T-Kat fork brace, XJ top end, YICS Eliminator, '80 carbs from Spyder Cycle Works, K&N Air filter, Fuse block, stainless steel valves & reg/rect from Oregon MC Parts. Raptor CCT, XJ air shocks, 850 FD, Sportster mufflers, Standard handle bar, Tusk Bar Risers, SS braided brake lines. Cat Eye speedometer. HID projector beam headlight, LED running lights.Comment
Check here for lots of good info from those who have gone before....
"A man should look for what is, and not for what he thinks should be" Albert Einstien.Comment
Aussie twist to the tale
Here's my version of the HID story.
I recently fitted a HID conversion kit to my '79 Special. I purchased a 50 watt kit with 8000k bulbs which give the blue tint. Admittedly, these bulbs offer less brightness/ intensity than the whiter / yellow tint bulbs but past experience with blue xenon halogen lights proved to me that the blue lights don't startle the wildlife in the same way as white ones, and given my riding territory and the abundance of kangaroos around here, blue was the way to go for me.
The twist is that I got a car based kit, which over here, cost about half what the cheapeast bike kit was worth. The upside is that I now have a spare ballast and bulb to use when the originals finally quit working. Downside is that there is no downside. The normal sized ballast fits neatly between the frame rails nestled behind the tilt switch housing under the tank. The wiring harness supplied was exactly the right length to reach the headlight shell which in Nathan's case, it will fit after drilling a 11/2 inch hole in the back of the bucket with a holesaw. The rest of the harness tucked neatly away beside the existing bike wiring harness and isn't obvious though mine's a naked bike.
End result is that I've got a brilliant headlight with the added bonus that it draws less current than the stock bulbs which is a major consideration for our XS11's wimpy alternator
Oh, yeah. Almost forgot. Mine's a Bi Xenon with the solenoid Hi/Lo bulbLast edited by Eveready1100; 10-07-2010, 05:25 AM.79 SF Special W/ Stock all original motor @ 384,000klms
*"The Keg"- UC torana hubs, XS11 discs, Tokico 4 spot calipersComment
Eveready, got any pictures of your setup?Nathan
I'll pull the seat and tank off and take some snaps on the weekend for ya.79 SF Special W/ Stock all original motor @ 384,000klms
Hmmmmmmmmm.... i wonder....
If purchasing a 'car kit', couldnt you use both for a dual headlight setup? i would think that the current draw with 2 of these should STILL be less than a standard bulb...right???
Now THAT would be some illumination!!!!
'81H (my first XS ) "Grey Ghost"
4:1 Jardine w/ headerwrap
Windjammer(wiring issues)
New paint/brakes to come!!
'80G FrankenBike (parts bike)
'80G to fix "BlackSunshine"
Stock Pilots/125 mains
Pod filters; 4:1 Kerker??
SS Brake lines w/ new M/C's
LED Brake Lite
Needs paint....
It is better to be thought a fool than to open ones mouth and remove all doubt....Comment
Slightly off topic but while stripping the bike I found this and wondered what it was exactly. It labelled "reserve lighting unit" and was mentioned in Dragon Tamer's post above (post #2). What is this and what does it do?US Army 1986-1991
1979 1100 Special (on the road after 16 years!)
1983 GS300L (wifes ride)
1985 Super Glide
2012 Super GlideComment
The reserve lighting unit automaticlly comes into play if you low beam stops working. It activates the high beam at a lower wattage (60% I think) and lights-up the "headlight" indicator on yor pilot box/dash, letting you know there'sa problem. Basiclly a back-up for your headlight so you're not stranded at night.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example"Comment
They sure put a lot of "extras" on these bikes, huh? I'm adding this one to the list of items that will not be used since I am building my own wiring harness. Thanks for the answer!The reserve lighting unit automaticlly comes into play if you low beam stops working. It activates the high beam at a lower wattage (60% I think) and lights-up the "headlight" indicator on yor pilot box/dash, letting you know there'sa problem. Basiclly a back-up for your headlight so you're not stranded at night.US Army 1986-1991
1985 Super Glide
Quote - Hmmmmmmmmm.... i wonder....
Actually Tom, it would end up pulling 50 watts per light which would still be a substantial power saving if you've already got twin headlights, plus of course you could get the 35 watt kits which would easily turn night into day and save more power.79 SF Special W/ Stock all original motor @ 384,000klms
anyone have any comments on this 35w kit?
http://cgi.ebay.com/ebaymotors/EFX-H...item3cada0d1a1
nothing said about hi/lo beamLast edited by SFerinTEXAS; 10-08-2010, 07:48 AM.79SF
XJ11
78EComment
