Wiseco Kit Source
  • Wiseco Kit Source
    Found a source of Wiseco piston kits which seems to be more reasonable than the usual $600 everybody talks about, they're $458 here. Check it out:
    These are the 1179cc
    http://www.motorcycleparts.biz/store...=piston-yamaha
    And the 1196cc
    And they have K&N filters for under $45
    http://www.motorcycleparts.biz/store...Code=kn-yamaha
    Hope this helps some of you in need of these items.
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
    Do they really have them in stock though?
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
      I highly doubt it, old site, old prices ..
      My cost on that kit as a Wiseco dealer is about $ 125 more ..
      1980 SG - "Blue Balls"
      Complete Restoration - Finished June 21/2010
      - 1179 kit
      - 80/81 carbs 42.5/115 mains with XS pods
      - Mac 4 into 1 exhaust
      - Venture auto CCT
      - progressive fork springs - no air
      - Mike's progressive rear shocks
      - Galfer S.S. Brake Lines
      - XSDirect - Black Coils
      - 8 mm S.S. Core Plug Wires
      - T.C. fuse box
      - TKat fork brace
      - Geezer regulator
      - Battlax BT45 V-Rated tires
      - 5W40 - Rotella T6 Synth Engine Oil
      - rest of bike is "good old Yamaha"
        If you're interested, contact them. This was meant as a favor to those who may need them. I don't.
        Kerker 4 - 1
        850 Rear End Mod
        Automatic CCT
        '82 XJ1100 (Sold)
          There are a few on Ebay
          http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
          1980 XS 1100SG
          Dyna 3 Ohm Hi Output Coils
          Pod Filters
          DynoJet Kit
          T.C.'s Fuse Block
          V-Max Auto CCT
            Looks like recent prices to me considering at the bottom of the page it says copyright 2010..
            '79 XS Eleven Special
            Kirker 4-1 exhaust
            Individual Pod filters
            Cafe Racer Fairing
            LED turn and brake lights
            LED underglow
              I got a bolt on 1179 cc kit with about 10,000 miles if anyone is interested.
                That sounds sooooo tempting.......
                  Old Design Wiseco Pistons
                  Wiseco redesigned the XS pistons about 10 years ago. The current stuff has anti-detonation grooves in the ring lands, slightly different skirts and some other subtle differences that make them a superior piece compared to the older design.
                  Piston wise, the new stuff is state of the art and the pistons that were made in the 80's are obsolete from an engineering standpoint and so a word to the wise, be sure you are getting the latest design pistons before you go through the time and expense of a big bore kit.
                  The older kits also came with the red head gaskets which are prone to leak and the ones made before 85 came with a head gasket that employed a neprene cam chain cavity gasket like that used on the 79-78 models.
                  Of course that's no big deal because you can get the current gasket from Wiseco or from Cometic who makes them.
                  Unfortunately nobody but Yamaha makes the good graphite head gasket anymore and they will not work with a bore diameter larger than 72.5 mm and they cost a $100.00 apiece.
                  Be forewarned, all big bore XS Wiseco piston kits are not the same.
                    That is very interesting!
                      Yes it is
                      BDF Special
