Questions about a '79 XS1100 Special
  • Sojourner
    • Feb 2010
    • 49
    • Cincinnati Ohio
    I *may* end up with a 1979 XS1100 Special. I say "may" since I am meeting him tomorrow to give him half of the asking price as deposit and I don't want to jinx anything. I drove out and had a look at the actual bike this morning. Overall it appears to be in decent shape- the tank has some internal rust, the battery is dead (he started it with a jumper box), and there's some cracking on the tires. Other than that, it looks decent. Never thought I'd be excited about a bike with a full fairing and hard saddle bags (including truck bag), but I am.
    So anyway. One of the things that struck me, and I saw this on an '81 I had for a summer a few years ago, is that the boots that go between the engine and the carbs are pretty cracked on this bike. The seller said it had carb trouble, but I think it's a vacuum leak in the boots. So here's my big question- what are these boots technically called? I seem to recall that they were a PITA the ass to find in decent shape. Is that still the case? And finally, where's a good place to find a decent set? Wasn't there a way to fix these with RTV sealant or liquid gasket?
    Finally, this bike has been sitting for about two years with periodic starts. Anything I need to baby or look out for?
    1979 XS1100 Special
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    They are called carb boots. They might be able to be saved if the cracks aren't too deep.They can be found many places for under $100.00 .
    If the bike has been sitting for a few years you might want to change the oil and drain the tank of any old gas and water before you try to start it up again. You will need to go through the carbs for sure and clean them up.
    BDF Special
    • TexinMaine
      • 160
      • Norway, maine
      I wouldn't go anywhere on them tires either. I am going the full dress route on my SG also.
      1981 XS1100H
      Quando omni flunkus moritati
      When all else fails, play dead.
        Called carb boots. They may only be surface cracks. There is actually a later of metal in them so its usually just cosmetic with them but.cM.crack all the way through. Georgefix has them, under 100. I would certainly drain the gas from the tank and the bowls and go through the carbs good.
        Also of you want to check and see if there are any vacuum leaks just spray the carb boots with carb cleaner and see if the idle picks up.
          Those carb boots can be bought on Ebay, from Parts-n-more, and other sources, typical price for a set of new ones is about $90.
          As stated the cracks rarely go all the way through. I'd pull the carbs and look inside for signs of cracking. The exterior, most folks use a product called plasti-dip on them.
          As to other things to look at and go through. Well, there is the FAQ on what to look for in a neglected XS, it is pretty comprehensive. I'd look at the brakes thoroughly, clean and replace fluid in them. Pull and clean carbs. Clean tank and petcocks. Pull valve cover , check and set valve clearances. Replace fork oil. Replace oils in engine, middle drive, and final drive. Also pull the final drive off and lube the dive shaft coupling gears and the gears where the rear wheel mounts.
          Definitely replace those tires. And to ensure trouble free operation, look into new fuse box, and replacing the wires on the pick-up coils. Also go through all the electrical connectors and thoroughly clean them up.
          A little bit of winter busy work to be done is all!
          • Sojourner
            • Feb 2010
            • 49
            • Cincinnati Ohio
            That's exactly what I was thinking- winter "busy" work.
            Thanks for all the help gentlemen.
            '79 XS1100 Special (I hope, let's not jinx it!).
            1979 XS1100 Special
            • Sojourner
              • Feb 2010
              • 49
              • Cincinnati Ohio
              Ok so I gave the guy a $250 deposit today and he's getting the title notarized, so I guess it's safe to call it mine (at least sort of). So here's what I bought.
              I welcome any comments or suggestions!! The Vetter fairing is in great shape, the hard bags (not Vetter) and the Vetter trunk are great shape too. The bike sounded good, though I still haven't ridden it. I figured for the $500 negotiated price and some $$/time over the winter, it was worth it. Normally I dislike fairings, but the first time I laid eyes on this ad something moved me. I knew that THIS was my bike. I know it sounds silly, but it really was love/enchantment/geas at first sight. I could feel the vibration, the wind in my face, and could hear a mixture of the engine's purr and Led Zeppelin's Immigrant Song in the background... Maybe I should really get out more?
              1979 XS1100 Special
                That sounds like a freakin steal of a deal! Nice lookin bike!
                • XS1100_OEM4ME
                  • Mar 2009
                  • 1619
                  • Fort Myers, Florida
                  Congrats!
                  Congrats on th 79, looks nice and low miles! 1st, don't fix the carb boots (intake manifolds) with gue or something, skip 5 order out pizzas this winter and buy new while you can still get them cheap, or at all, for that matter. Next, don;t start the bike again till you have gone through the carbs (all the way through), cleaned out the tank of ALL rust, changed all fluids, oil, gear (mid and final) break fluid, and new gas. Running that old stuff through the motor, drive and carbs can make your life a lot harder New air filter, batt and check/change the fuse box. You will be glad you did My photo's of my 79 are in my profile, good to see a new 79 owner!
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
                  • Sojourner
                    • Feb 2010
                    • 49
                    • Cincinnati Ohio
                    Here's a quick question...
                    There's a 1.5" end of a shaft sticking out the side of the engine and the wording cast into the engine says it's for a kickstarter? So is it possible to pry off the plastic cap and mount a kick lever onto it? Does it require anything else to be done aside from mounting the lever? I know it sounds crazy, but there's something inherently satisfying about about kicking over an engine rather then simply pressing a button.
                    The third pic in OEM4ME's gallery made me think of it.
                    A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
                    1979 XS1100 Special
                      There is probably still the kick start lever under the toolbox held in by a wingnut from the right side. The cap should just slide off and the lever just slips on.
                      • XS1100_OEM4ME
                        • Mar 2009
                        • 1619
                        Kick start
                        http://s955.photobucket.com/albums/a...t=XSmotor.jpg&
                        There should be a wing nut on a cover close to that shaft that if removed, will let you pull out the OEM kick starter that will fit over that shaft after you remove the rubber cover. If not there anymore, you can get a kick started on ebay cheap
                        1980 XS1100 Special
                        1990 V Max
                        1982 KZ750 LTD Twin
                        1974 CB750-Four
                        Past/pres Car's
                        • Sojourner
                          • Feb 2010
                          • 49
                          • Cincinnati Ohio
                          So is there any issue with leaving the kickstart lever on there permanently?
                          1979 XS1100 Special
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            kick
                            If you want to do that, you will want to get a spring loaded return kick from the other XS's I hear the 750-850 XS's work ok, rubb the air box, but work. Why would you want a kick, these bike start every time when running/charging right and can be push started in a pinch
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
                              No problem leaving it there other than its in the way of your leg, at least it is for me.
