Hey all, I bought an 80 1100 special and the big boot covering the shaft u-joint is cracked,was wondering if one of a 78-79 would fit an 80?Thanks:Rick
Drive Shaft Boot
Drive Shaft Boot
1980 XS 1100 replaced the seat and sissy bar from a XS 1100 standard and changed the handle bars. Did not like the original bars at all.No mod at all except for a four into one header.Tags: None -
Yep... any of these off any XS/XJ11 will fit, and Yamaha used the same boot on some of their smaller XS/XJ shaft-drive bikes, so you have lots of choices...Fast, Cheap, Reliable... Pick any two
Yep, can't leave nuthin' alone... -
1980 XS 1100 replaced the seat and sissy bar from a XS 1100 standard and changed the handle bars. Did not like the original bars at all.No mod at all except for a four into one header.Comment
Yeah, it's a bit of a PITA to change. If it were me, I'd pull the boot out of the way and disconnect the driveshaft at the middle drive, then pull the rear wheel and final drive. Push the driveshaft back, change the boot, then reassemble. I think some have managed it by just disconnecting at the middle drive and pushing the u-joint back on it's spline, but that can be a real battle...Fast, Cheap, Reliable... Pick any two
Better yet, take the swing arm bearings out, clean them, regrease them, and while the arm is loose, put the new boot in.Yeah, it's a bit of a PITA to change. If it were me, I'd pull the boot out of the way and disconnect the driveshaft at the middle drive, then pull the rear wheel and final drive. Push the driveshaft back, change the boot, then reassemble. I think some have managed it by just disconnecting at the middle drive and pushing the u-joint back on it's spline, but that can be a real battle...
When was the last time you checked the swing arm bearings?
CZ
Easy way
Just undo the universal from the middle drive and it will move back far enough to replace the boot. No need to drop the swing arm. Only 4 bolts removes the universal.You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesComment
