do i need new diaphrams??
  • nadcevb
    • Sep 2010
    • 1
    • nashville
    wat up guys i need some help. i got a 1980 xs1100 bobber and i think my carbs might be screwed up. it will idle fine but when i take off to go it seems to sputter out and i have to pretty much keep it full throttle to get anywhere and it sounds like it misses bad when i get on it like that. i have heard i need new diaphrams which might make since seeing how there is silicone on them apparently. ive also heard that one of my needles might had been clogged up which would also make since seeing how it ran ****ty for like a month then all of the sudden it ran right on for like two days but then started missing again. im totally confused somebody help me out so i can ride again before the end of time!
    SeX DrUgS AnD RoCk AnD RoLL!!!
    You need a thread of hope!!!
    Namely the thread on Carb Cleaning 101!!! Do a search on "carb Cleaning 101" and you will find complete details on how to disassemble, inspect, clean , clean some more, and then clean some more, and THEN reassemble the carbs.
    If they were that dirty in there, then there is no substitute for tearing them down and cleaning them up. Anything less and your just chasing deamons.
    If indeed you do need new diaphrams, they can be purchased. Parts N More has the ones for the 80-81 model carbs for $64 each.
    • CatatonicBug
      • 6117
      • Clinton, UT
      Yep. Clean the carbs. Don't focus on the diaphragms until you get in there and look at them though. Spend a good 2 hours, 2 cans of carb cleaner spray and a bit of compressed air, and you'll be glad you did.
        For sure you need to clean them out first. after that then you can see better what might be going on.
        • MeatTooth
          • Apr 2009
          • 175
          • Tulsa, Oklahoma
          mine did that too.....then I had my carbs ultrasonic cleaned and installed the stage 3 dynojet kit and all is right with the world. I was blown away when I pulled my needles out and 2 of the 4 had severly bent tips?!?!?!? How do you bend needle tips?
          Tulsa, OK
            My dad always said I could F-up an iron ball!!!!
            • Rasputin
              • 3180
              • Lacombe, Alberta, Canada
              Don't forget to check the pick up coil wires. They can lead to a myriad of symptoms one of which you are describing.
              2-79 XS1100 SF
              2-78 XS1100 E Best bike Ever
                Those freakin pickup coil wires cause every freakin symptom imaginable.
                • Rasputin
                  • 3180
                  Thus the word Myriad!
                  2-79 XS1100 SF
