Hey guys, I've been a lurker since joining this very informative site and now I come to you requesting your expertise.
First, before the issue, i'll give a few details about the motorcycle. It is a 1979 Yamaha XS1100 Special. I put on a set of MAC 4-2 Turnouts on it as well as had the carbs cleaned and the bike tuned in the spring of this year. Have had next to zero issues since having that work done. It has around 23,000 miles.
This evening, I was going to go ride for a while...that was until I started my bike. It was a little sluggish to start (which is usual, just have to give it a bit of gas). Immediately upon starting, it produced the aforementioned "big bang" yet still held an idle. From what I could tell in the garage, it was not a backfire. The sound did not exit the exhaust. The RPM's went up like usual at full enrichment so I pushed the choke in to middle position, When the engine was little quieter, I heard what sounded like a metal on metal scraping noise. It wasn't grinding as much as scraping. However, it was still idling normally. I immediately killed the engine. My roommate, who crapped himself inside at the bang, came outside to see what the hell happened. He suggested it could have been a blown or cracked connecting rod on one of the pistons assuming one of the cylinders filled with gas. We removed the timing the cover and manually turned the engine to see if it would produce the same noise and if the cylinders went through full stroke. They appeared to function normally I however do not possess the tools necessary to perform a compression test.
I have no idea where to go from here. Any suggestions, tips, solutions, whatever will be greatly appreciated.
Thanks in advance!
Thanks in advance!
I can picture what you're saying...so leaky petcocks plus leaking float valves = gas overfilling the float bowls, and draining back into the airbox. We push the ignition, and somehow the spark makes its way to the airbox, igniting any fuel/vapor trapped there, hence the explosion. Jeremy, if that's the case, you're lucky the airbox didn't explode and send plastic shrapnel into your junk
