Snap Ring Removal
  • aviatorkev
    • Jul 2010
    • 11
    • Knoxville
    Snap Ring Removal
    ...so when you want to change the position of the clip on the main jet, how the heck do you get the snap ring out? Every pair of snap ring pliers I've seen is too big to fit down in the slide to get to it. Is there a special tool for this, or a supplier of specialty tools you guys use to get the proper pliers?
    My XS is a '79 Special, if you need that info. Thanks for the help guys!
    1979 Yamaha XS1100 Special (Cafe Project)
    2003 Honda ST1300 (Daily Driver)
    2003 Suzuki DR-Z 400S (Dirty Beast)
    ...obviously I need a Kawasaki of some sort.
    I for myself a cheap snap ring pliers and ground it down on the sides so that it fit. Miles cd sells a long reach pliers that supposedly works as well.
      I believe he meant Mikes XS. I have also used a couple small diameter rat tail files, using the round pointy end to put into the snap ring holes.
        If you have a set of 'interchangable tip' snap ring pliers, pick up a couple of single allen wrenches that fit the pliers, cut off the 'L', grind/file a tip on them and you now have a set of 'long reach' pliers...
        Cost you under .50....
        • GARTHXS
          • 1631
          • Seattle
          I got a set of interchangeable ones from home depot they seem to work fine just put the tipps all the way out
          91 kwaka kz1000p
          Stock
          ( Insert clever quote here )
            Why not just unscrew the cover plate and pull the needle out. Then push the snap-ring off with a screwdriver, and slide it back on in the location you want it. Slide the needle back into place, and screw the cover plate back on...
              • 3180
              My older style set of carbs has the snap ring and not the cover plate that the newer style have. They can be a real pain in the hoo-hoo.
              I just took an old set of needle nose pliers and ground the tips to fit in the snap ring holes. Works great. Of course it is now a specialty tool but it works on the brake snap rings and other stuff so that is not so bad.
              • aviatorkev
                • Jul 2010
                • 11
                • Knoxville
                Thanks for the ideas guys, I cut the sides off my convertible pliers, making them an inside snap ring only set, and it fit. Now it's time to start the painful process of remove carbs, remove tops and change clip position, reinstall tops, reinstall carbs, test ride, rinse, repeat...
                  You can pull the needles without removing the carbs.
                    • 5050
                    Wear safety glasses!
                    • GARTHXS
                      • 1631
                      • Seattle
                      heres what I use
                      http://www.northerntool.com/shop/too...8959_200308959
                      91 kwaka kz1000p
                      Stock
                      • rpgoerlich
                        • Dec 2007
                        • 643
                        • Katy, Tx
                        This is what I use for master cylinders and slide circlips:
                        Richard
