My recent aquisition to my fleet
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    I would like to thank Big Daddy Funk for the opportunity to purchase his "Hot Rod" . I went to his place in North Bay Ontario and picked up the now BDF Special.
    Here's a shot of a couple of my 80SG .
    BDF Special
  • Big Daddy Funk
    • 639
    • Brantford, Ontario, Canada.
    A little more info...
    To be a little more precise. 1196 Wiseco big bore kit, Mega Cycle Cams, slotted cam gears, ported and flowed head, bronze intake seats, Dyno Jet kit, Mikes XS green coils and air pods, Clutch mod, Mac 4 into 1 with custom built and tuned baffle, Oil cooler, Dyno tuned to 98 hp at the rear wheel.
    Best of luck bro. Enjoy and hang on tight.
    BDF
    I May Be Crazy, But I Have A Good Time.
    Northern Gypsy - 2010 Kawasaki Concours 14 ABS - Daily rider
    • 11Rider
      • Aug 2010
      • 331
      NICE. What's it like to ride that beast?
      '79 XS11 Special, fork gaiters, Uni pods, 45 pilots, 140 mains, ditched the octy, solo seat, T kat fork brace
      Purrs like a kitten, runs like a scalded cat
      • Elevener
        • 608
        • small town in TEXAS
        I know I could search, but how bout some shots from the other side? Nice bikes.
        Trapped in time. Surrounded by evil. Low on gas.
        1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
        • tinman905
          • Aug 2007
          • 946
          Well I wasn't expecting too much difference between my stock SG and BDF HotRod but when I took it for my first ride. I was shock with the torque and the top end horsepower band . I had a grin on my face that would not go away for days haha! The torque is unbelievable it will rip the handle bars out of your hands if you don't hold on and the top end is more than I will ever use. The exhaust has been modified also and the sound is just amazing.
          Rick has built an amazing bike the time and effort he has put into this bike is beyond what I would ever imagine. This bike has the ability to reach over 120 mph fast and with no effort.
          I plan to swap over my Vetter fairing and bags so I can enjoy this bike when the colder temps arrive but look forward to next spring when the chain drive and swing arm conversion is installed . The Vetter package will most likely come off again.
          Here's a few pics of the other side
          BDF Special
          • TexinMaine
            • 160
            • Norway, maine
            Nice looking bike. How do you like that Saddleman seat on your other SG? I have been contemplating buying one.
            1981 XS1100H
            Quando omni flunkus moritati
            When all else fails, play dead.
            • dpotter58
              • Aug 2004
              • 1866
              • Southern Maryland
              Maybe I should make another thread and ask but, how do you tune a baffle?
              1980 LG
              1981 LH
              • tinman905
                • Aug 2007
                • 946
                I love it! It's very comfortable on long rides but I have reshaped the foam under pad with a mini grinder .First was to reduce my seat height and then I formed it for comfort. It really made a difference shaping the foam with a mini grinder .
                The seat foam and cover was hanging over my tank a bit more than I liked so I shaved it back a bit.I found it was marring the paint on my tank just a bit higher than I liked. I was lucky after a couple of test runs I managed to remove just enough foam in all the right places. It wasn't difficult to do but taking a small amount off each time will insure you don't spoil the seat entirely.
                BDF Special
                  Hi Duwayne,
                  Not sure of the technicallities but I do know a winter spent on the Dyno with a full fab shop and expert tuner had something to do with it
                  Perhaps BDF would like to explain (using small words)
                  • tinman905
                    • Aug 2007
                    • 946
                    The only way I know is using a Dyno and having a friend with a $40,000 Dyno really helps.
                    BDF Special
                    • Big Daddy Funk
                      • 639
                      Baffled
                      I would imagine that all the header/exhaust companies have engineers to do mathematical equations to figure out flow rates and such.
                      Us backyard guys have to do trial and error to narrow down exhausts pipes and baffle sizes.
                      Starting with a quality head pipe from a good manufacturer is a great start.
                      4 into 1 system seems to produce the best results.
                      Tuning a baffle is best done on a dyno. Start with a stock size baffle and do a pull. Move up a1/4 inch in diameter and do another pull. Continue size increases until the HP and Torque numbers stop climbing. That would be a tuned baffle to your current engine tune,
                      Having done that, further increases are possible by changing carb flow, jet sizes, ignition and cam timing and a host of other things, all of which may neccesitate another baffle change.
                      If you have a muffler can with a removable baffle, making a straight flow through baffle is not difficult with some perforated metal and insulation wrap.
                      It is amazing how much torque and HP you can get from a good dyno tune.
                      With the help of a good tuner most bikes will get a 10% increase with no hard parts changed.
                      BDF
                        With a Supertrapp can, tuning is made easy.
                          BDF
                          Hi BDF,
                          OK Now tell them about the inlet side
