Are you talking about the rubber pieces, or the carbs themselves? All 4 of the rubber pieces should have vacuum ports on them, and those are used for sync'ing the carbs. The Advance line does NOT connect to any of those 4 ports. It connects to the actual carb body. Do all 4 of your actual carb bodies have ports too??
Mikuni Carbs
-H. Ford -
Since I got the bike the vacuum advance has always been attached to the #1 rubber intake manifold. The #2 carb does have what appears to be a vacuum port available but it has always been capped off. Any thoughts????Comment
Yeah.. It's backwards! Put the vacuum advance line on the #2 carb port, and the cap on the rubber manifold. The only thing that should be connected to the rubber manifold ports is the vacuum-operated petcocks (on the Standards) or the octy (on the Specials). If you have manual petcocks, all 4 ports should be capped off.1980 XS850SG - Sold
-H. FordComment
When I put the carbs back on I will attach the advance to the #2 carb. Just like my wife...Works no matter what hole you use.Comment
The main thing to note here is the port is only open to manifold vacuum when the throttle is open. If it's open at all times, that may explain why yours is set-up the way it is; the PO may have got the 'best' results that way. But you may still have issues with the vacuum advance coming in at idle/too fast/too slow/not enough, depending on how your damper is adjusted.Fast, Cheap, Reliable... Pick any two
The exploded view of the carb shows the Cap over the port as a vacuum cap. Why the PO used the manifold who knows..If I hook up to the #2 Carb and it does not work out changing back to the manifold is a easy fix. Thanks for the help.Comment
