Valves
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    Valves
    I need a 78-79 exhaust valve for a sample to get the order rolling. I'll settle for one slightly bent better exhaust valve but I could use an intake too. I can return good samples after the order comes in.
    Can someone help? I really don't want to tear apart a good engine to get a couple of valves.
    Geezer
  • Bullet
    • May 2007
    • 185
    • Alliston | Ontario | Canada
    I got 1 of each ( 79 intake and exhaust ) and they are not bent .. gotta pull them out of a head , but no biggie ..
    You can send them back with my order
    PM me your info tony ..
    Dan
    1980 SG - "Blue Balls"
    Complete Restoration - Finished June 21/2010
    - 1179 kit
    - 80/81 carbs 42.5/115 mains with XS pods
    - Mac 4 into 1 exhaust
    - Venture auto CCT
    - progressive fork springs - no air
    - Mike's progressive rear shocks
    - Galfer S.S. Brake Lines
    - XSDirect - Black Coils
    - 8 mm S.S. Core Plug Wires
    - T.C. fuse box
    - TKat fork brace
    - Geezer regulator
    - Battlax BT45 V-Rated tires
    - 5W40 - Rotella T6 Synth Engine Oil
    - rest of bike is "good old Yamaha"
    • Geezer
      • May 2003
      • 2985
      PM on it's way.
        • 1377
        Genetic Drift???
        Tony,
        I haven't installed the last 78-79 SS set I received from you. If you need a pair then let me know.
        The valves made from this pair would be a copy of a copy if you know what I mean....
        • Bullet
          • May 2007
          • 185
          larrym,
          yep, you are a lot closer to tony than me and this would speed up the order run too ..
          - 1179 kit
          - Venture auto CCT
          - T.C. fuse box
          - TKat fork brace
          - Geezer regulator
          • Geezer
            • May 2003
            • 2985
            Originally posted by Larrym
            Tony,
            I'm trying not to send them new valves if at all possible. I'm about ready to pull the head off the engine in my 79 parts bike but it only has 34k miles on it...
            It's too bad I didn't save the bent valves out of Poprocks XJ cylinder head but he's offered ones out of a spare head and I just might ride over his way to get them if all out falls through. At this very moment I only have one new late XS/XJ intake (not stainless.)
            Geezer
            • mack
              • 2411
              • Ontario, Canada
              Valves
              Tony I have a spare head with original valves. Will send a set if you need. I don't have your address but you have mine.
              mack
              79 XS 1100 SF Special
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              https://youtu.be/wB5Jfbp6SUc
              https://youtu.be/RaI3WYHSuWA
              Frankford, Ont, Canada
              613-398-6186
              • Geezer
                • May 2003
                • 2985
                If I locate a couple valves from the lower 48 by the end of the holiday weekend, I'll get back to you... I find it hard to imagine that there aren't any bad early XS11 valves around...
                Geezer
                • mack
                  • 2411
                  • Ontario, Canada
                  Oh Oh I know this one
                  Thats because there is no such thing as a bad early XS 11
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                  • Geezer
                    • May 2003
                    • 2985
                    Bad valves, not bad XS11, bad bike or even bad wolf....
                    Geezer
                    • Geezer
                      • May 2003
                      • 2985
                      The valves are on the way and are supposed to be here on the 24th. I'll send them out the next day.
                      Geezer
                      • mack
                        • 2411
                        • Ontario, Canada
                        81 LH Valves
                        Are all the 81 valves spoken for? I haven't gotten into the head yet but, I may need a set for this restore. Checked the shim's before I pulled the head and the PO had replaced the shims but went the wrong way. After I got the head off, I see that the carb boots are partially melted and a lot of paint has been burnt off. It must have got real hot so I figure the valves may be cooked. Hurt my back a while ago so I haven't been able to stand for any period of time yet but hope to get the valve trains out next week and have a look.
                        mack
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        613-398-6186
                        • Geezer
                          • May 2003
                          • 2985
                          The valves are in and now on the way to those that ordered them. I'm sure all will be very pleased with the results...
                          Geezer
                          • James England
                            • 3039
                            • North of England
                            Do you have valves for the 1979F model? What do they cost please?
                            • Geezer
                              • May 2003
                              • 2985
                              PM sent...
                              Geezer
