Random Stumbles
  • gixxer
    • Jun 2008
    • 27
    • Eastern Canada
    Random Stumbles
    This is my third season with this bike and have had absolutely no issues with it. A couple of weeks ago it started to randomly stumble. This can happen at low speed or high speed. On one occasion it actually paused and backfired twice before resuming normally. Very annoying at highway speed. I'm having a hard time correlating the stumbles with any particular event. Sometimes it stumbles when I accelerate after a deceleration. Sometimes it seems to happen after I've gone over a bump which could be the decel / accel again I guess. Sometimes it just happens as I'm rolling along smooth pavement at a steady speed. Maybe I'm getting paranoid about this now but the bike sometimes feels to me like I'm riding into a strong headwind even when there is no wind, like it's stumbling almost imperceptibly all the time.
    I replaced the plugs. No difference. I removed the coils and found one with a crack in it and said 'Ah Hah!' Ordered a set of NOS coils and installed, still same problem. I dismantled everything, cleaned and reset every connector I could find. Still stumbles.
    I removed the carbs thinking maybe I had a problem with fuel delivery. Everything looks super in there. Float heights are perfect. Gave them a good cleaning while I had them off. The bike has been running a bit rich so I tweaked the idle jets while I was at it then re-installed the carbs. The problem is still there. No better, no worse.
    I checked the pickup coil and wiring. Don't see anything wrong there. Opened up the TCI box for a look. Nothing burned or obviously wrong there.
    Don't know what else to do. I'm at the end of my rope. Anyone with any ideas?
    '81 XS1100 H
    Special Tank
    Special Headlight
    You say you cleaned the carbs, but how thoroughly? Did you pull the needles AND the seats? Did you pull out the emulsion tubes and the pilot jets? Have you sync'd the carbs lately? You'd be amazed at how much difference a carb sync will make.
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      Ok, you said you "looked" at the pickup coil wiring. Did you check the pickup coil resistance and tug the wires while doing so? It sounds like it could be pickup coil issues to me. I have not had those issues myself (knock on wood) but many have, and everything but the XJ's can get the problems as they ALL have the vacuum advance which is the ONLY thing in the timing system that makes the wires flex when it operates. Make sure you try to stretch them, but don't pull too hard as they ARE fragile and pulling too hard can make good wires bad. But if they will stretch, they are likely the problem, and if you pull them and move them around while it's idling if they are bad it will likely show up then.
        • 8891
        +1 on pickup coil wires.
          +2 on the pick-up coil wires. Give them a pretty good tug, and watch especially where they are retained by a crimp fitting just before they leave the case. Open the crimp when you do this, then squeeze it back after you're done.
            • 3193
            +3 on the pick up coil wires. Could not have more accurately described my probs with them if you were here when it happened.
            • gixxer
              • Jun 2008
              • 27
              • Eastern Canada
              Broken Pickup Wires
              You guys are right on the money. Three of the four pickup wires just inside the little clip are stretchy, like the wire is broken inside them. I don't know how the bike worked at all. Found your tutorial here on fixing this Ken. THANKS guys for the great advice. You guys have got a place to crash if you ever come out to the east coast of Canada for a run.
              '81 XS1100 H
              Special Tank
              Special Headlight
              • FANNING507
                • Jul 2008
                • 103
                • south central Kansas, Turon
                Guys, I know that's my issue. Been trying to find the short; off and on; for 60 days. I need the specifics on how to check the resistance. Perforate the insulation? Is there a logical starting point and ending point.
                Forgive my ignorance, but I don't want to make it worse than it is. Maybe I need a picture. It's not in the manual's where to position the mutimeter.
                The wire is certainly very soft and flexible and I don't want to mess something else up.
                '81 XS11 LH (MNS)
                "On a scale of 1 to 10, I have an eleven!"
                "Excess is easier to say than XS,"
                  It's not about checking resistance. You take the timing cover off, and pull on the wires. If the metal strands inside the insulation allow the insulation to stretch, you know they are broken, and need to be fixed. A nice firm tug should be good, since you might still have a few strands of the wire left, but not enough to make good contact. The firm tug should brake the last few strands if they are weak enough to have been causing the problem.
                    Here is the link to the pickup coil fix Hanning http://www.xs11.com/forum/showthread.php?t=543
                    • gixxer
                      • Jun 2008
                      • 27
                      • Eastern Canada
                      Whoa!
                      Fixed my three pickup wires (http://www.xs11.com/forum/showthread.php?t=543) and took ol' Betsy out for a run. I know now that the vacuum advance has NEVER worked on this bike since I got it. I was happy with the power it had before but now, it's SCARY! Smooth as silk at all speeds, not a single stumble. It's even smoother during shifts because the revs are not dropping so quickly and it's riding better because the engine isn't stumbling when I hit a bump.
                      I feel like I just got a new bike, thanks guys!
                      '81 XS1100 H
                      Special Tank
                      Special Headlight
