Drive shaft boot?
  • chanley28
    • Aug 2010
    • 13
    • Joliet, IL Area
    Drive shaft boot?
    My drive shaft rubber boot is torn, and looks like it is in bad shape. It looks like it will stay for now, but my guess is that it will be a pain in the ass to replace, or find for that matter. Does this boot get filled with grease, like a CV Boot on a car? or is it just to protect from debris? I would like to know if any of you know the purpose of this boot, so I handle this accordingly. Thanks
    1982 XJ1100J Maxim
    MAC 4-1 Megaphone Exhaust
    Chicago Area
    Working on/Looking For:
    Crash Bars
    Saddle Bags
    Taller Sissy Bar
    Turn Signals (all 4)
    Windshield
    A Lot of Little Stuff
    It's a dust cover, and it keeps junk out of the drive shaft linkage. It's a good idea to have it on there, and yes, it's a pain to replace, but can be done in about 2 hours or so. If you pull the swingarm (and the driveshaft with it), that will allow you to grease the swingarm bearings while you're in there too.
      I'll add that this is a fairly 'common' part, and can be found on more than just the XS/XJ11. This was also used on the XS triples, as well as some of the newer 'smaller' XJ bikes.
      • planedick
        • Mar 2005
        • 2068
        • Yorba Linda, California
        Easy
        It's not necessary to remove the swing arm at all. just remove the four bolts between the u-joint and the middle drive and the boot will fit between the two for easy replacment.
        Drilled airbox
        Tkat fork brace
        Hardly mufflers
        late model carbs
        Newer style fuses
        Oil pressure guage
        Custom security system
        Stainless braid brake lines
          To me, those 4 bolts are just about impossible to get to. That's why I preferred to go with the swingarm myself. Plus the benefit of being able to access the bearings. YMMV.
          • planedick
            • Mar 2005
            • 2068
            It's easy, box end wrench, hammer, just tap the wrench with the hammer and they come right out. I've done it before when I changed mine. Hardest part was getting the little spring thing on the back side of the boot.
            Drilled airbox
            Tkat fork brace
            Hardly mufflers
            late model carbs
            Newer style fuses
            Oil pressure guage
            • SFSPECBIKER79
              • Jul 2008
              • 403
              • NC
              reboot
              i have a boot for 80 special if that will help. send pm
              79 xs 1100 spec & 80 xs 1100 g
                New Boot
                You should be able to buy the boot at the local dealer or or BikeBandit has it for $71.20.
                I looked up the part number for XS1100SG, it's 2H7-22189-00-00.
                You can source it from YAMAHA SPORTSCENTER for $47.28.
                • TADracer
                  • 1417
                  • Kenner, Louisiana USA
                  Chanley, part two of your question....the boot DOES NOT get filled with grease like a CV joint. It is a dust/debris cover only.
                  Mike Giroir
                  79 XS-1100 Special
