So there I was, getting ready for a nice, long, uneventful trip up north starting tomorrow and I decided to gleep the stainless steel brake hoses from Bush, my '79 Special, because the front brakes on Columbo have been getting a little mushy.
As I rolled Columbo into the garage and stopped, ye olde right front brake line popped down by the caliper banjo fitting and the brakes died instantly as brake fluid went everywhere but into the calipers.
The 'new' stainless steel hoses fit nicely. It took very little time to bleed the air out of the system and the brakes definitely work much better than they did with the old rubber hoses. I didn't take any pictures but the old hose split open radially at the end of the banjo fitting. There was no sign of cracking or bulging on any of the old hoses two weeks ago when I replaced the stock brake disks with the slotted brake disks from the XJ and put in all new brake pads.
From looking at it I would guess that someone let the front brake calipers hang by the brake hoses instead of supporting the calipers with a piece of wire attached to the fender when they changed the front tire or worked on the brakes.
Yes, it's my lucky day! I was >that< close to heading out on the road tomorrow morning and I wouldn't have made it past the first stop sign.
still have the little rings on them that say 1977 DOT This winter they are getting changed!!!!! Brakes still feel nice and firm in the front. Rears dont work so well. There was some crap (probably rust) in that short chunk of steel line that I had to clean out to get anything out of them. They help and slow me down some but not well. This winter will be a big winter for her. After about 17 years she is finally going to get the attention that she deserves! And those brake lines are going to be right up near the top of things to do!
