Dynojet kit messes with choke?
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Cat
    Thanks for the detailed description Clint! The fact that we can't see the actual flow of air and fuel while running seems to make these carbs a bit mysterious sometimes. The more times I take them apart, the more I slowly begin to learn how the physics actualy functions inside them.
    Yes. Once the engine is warm, which does not take an unusually long time, and I push the choke lever in, everything runs perfectly.
    I had not messed wth the float levels since I got the bike, since I never seemed to need to. Plug color was always really good, and sync and colortune (at idle) always worked great. However, when I pulled the choke lever, the RPMs would always slowly climb over 4K. I'd push he lever in the 1/2 choke, and the RPMs would drop, then slowly climb to 4K again.
    Now, after the Dynojet kit was installed, I noticed my plug color was super WHITE! That, along with the strange change to the way the engine responds to the choke made me start wondering what was going on. So, I decided that I should check the float levels. They were set REALLY lean, based on the manual for the '80 carbs (I have an '81, so generally fuel, not foat, levels are measured with the carbs ON the bike). I richened the float levels, and set them to the exact setting that the manual calls for on the 'SG. Of course, this didn't affect the choke response (I'm learning while I'm doing this).
    I just read this in another thread:
    After instaling the Dynojet kit, this describes exactly what is happening. I guess my main concern is that, since I ride all winter, in temps below freezing, I am worried that the "new" choke respose will affect my ability to start on cold mornings. However, if the new choke response is "normal" then I can simply ignore it and wait for the winter temps. As mentioned earlier, everything else is running perfectly. Should I just smile and be thankful that the Dynojet kit put my choke response back to were it is "supposed" to be?
    Cat, my "gues" is that your new rich mix will help your winter start ups and your choke working like is should now will continue to do the same in very cold weather, how be it, you will want to leve it at full and half a little longer, you may even want to start your cold weather rides on half for the first few min. If your bike run's like I said the new ones ran, then your mix, even with mods is giving the motor what she needs, please let me (AND all the other's who think I don't know what I am talking about) know if she doesn't run just like I said this winter Good luck with your bike
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    • Joab
      • Aug 2010
      • 472
      • Ozark, Alabama
      You people break my brain on a daily basis. Keep up the good work.
      Joab
      "If nothing else, it will be interesting..."
      ______________________________________________
      1979 XS1100SF
      1972 XS2 650
      Ozark, Alabama
      • 79XS11F
        • 3563
        • Ottawa, Ont. Canada
        It this factory manual layout of the pilot circuit it appears that no air is being added. Just additional fuel. All air still appears to enter through the carbs mouth as it would under normal use conditions.
        In any case, I can in deed get my bike to fast idle correctly by holding the chock at different positions then the rod detains are set up for.
        Rob
        KEEP THE RUBBER SIDE DOWN
        1978 XS1100E Modified
        1978 XS500E
        1979 XS1100F Restored
        1981 Suzuki GS1100
        1983 Suzuki GS750S Katana
        1983 Honda CB900 Custom
          See that little arrow on the top of the choke plunger in the diagram. The is open to the cavity under the diaphragm but above the slides. That area is open to the airbox through another hole. So in theory it could easily be sucking in extra air through that opening. Jat
          • 79XS11F
            • 3563
            On my carbs there is no hole or blind plug at that location. The fuel also appears to be being added on the engine side of the butterfly which is never fully closed. I don't have a side view of the set up but yes, there may be a small hole to the underside of the diaphragm. I will check it out when I am in the garage later today.
            Rob
            1978 XS500E
            1981 Suzuki GS1100
              Rob
              Maybe the later carbs are different but my 78 carbs have a rather large hole there, maybe 1/8 to 3/16 of an inch across.
              • 79XS11F
                • 3563
                My carbs are 78 / 79 ?
                rob
                1978 XS500E
                1981 Suzuki GS1100
                • 79XS11F
                  • 3563
                  Rob
                  Yes there is a small hole from the underside of the diaphragm and into that fuel circuit so air is also being delivered when the chock is activated.
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
                  • clcorbin
                    • Jan 2010
                    • 495
                    • Albuquerque, NM
                    The air IS getting added in there Rob. That is just one of the facts of life in internal combustion engines: Friction is a function of engine speed. To increase engine speed, power MUST be increased to overcome the higher friction. To increase power, larger volumes of fuel AND air MUST be introduced into the engine.
                    The diagram makes it look like the extra fuel is completely blocked off when you push the "choke" into the half "choke" position. I doubt that for some reason. The people that draw these diagrams are not usually the engineers that designed the carb. Often, the diagram only has a vague relation to the actual operation of the part in question.
                    -- Clint
