New Carb set
  • Alan1982XJ
    • Aug 2010
    • 29
    • Olympia, WA
    New Carb set
    Picked up a new carb set off another XJ1100 82 and well...
    The screws on the top of the carbs, not a one of them will loosen I've already actually almost stripped one of them but man.. I've about broke my hand trying to twist these buggers off.
    Impact drivers I'm told are the best option, is this true? just want to make sure before I buy the nice set I was thinking (For future use of course in mind)
    Let me know mates.
    1982 XJ1100
  • GARTHXS
    • 1631
    • Seattle
    Try some pb blaster let em soak a while. I use my cordless drill that has a clutch on it and that usually works the bit is a medium one
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      • Fort Myers, Florida
      Soak
      Let me know mates.
      Oil soak cant hurt, you can get a cheap impact driver at many places, use good bits and mount the carbs solid, vice with rags to keep level impact. Tap strait and solid taps till they come lose. A 1/4" air impact would be best under low air presure, but the manual one will work, take your time and break them lose slowly I would replace them with stainless steal alen head screws JIMHO
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
      • Denmark64
        • Jul 2010
        • 1
        • Pedersker on the island Bornholm in Denmark
        Drill
        I had the same problem whit a few of the screws on my cabs, I decided to use a drill to get them out, used a drill that was smaller than the screws diameter, it worked.
        Used a tap to “clean out the tread” afterward, and then replaced all the screws whit stainless, it looks great to :O)
        • SFerinTEXAS
          • Jun 2006
          • 877
          When they are that tight I use long nose vice grips like these
          79SF
          XJ11
          78E
          • 4strokes
            • Aug 2010
            • 11
            • Guntersville, Alabama
            http://www.google.com/products/catal...d=0CCgQ8wIwAQ#
            Good tip ... I use the long nose vice grips here in my shop on a regular basis & it's a 9/10 chance it'll work everytime. Just get a good bite and it'll pop loose.
            1980 XS Eleven SG all stock except Kerker 4/1 header & K&N.
            1974 Kawasaki Z1 900 bored to 1328cc motor w/ported J head & titanium valves.42mm Mikuni carbs.
            2002 SS Monte Carlo
            2004 Silverado
            • davidsymons53
              • 197
              • Peterborough, Ontario
              Vice grips work!
              1981 XS1100 Special
              Previous Bikes
              1999 Honda Goldwing Aspencade 1500
              1983 Honda Goldwing Aspencade 1100
              1982 Honda CB900c
              1984 Honda vt750 Shadow. My son's bike now.
              1984 Honda vt500 Shadow
                • 8813
                Another good method is to put a #2 Phillips driver bit into a 1/4" socket with a 3" extension and a ratchet. This provides much more torque and downward pressure than a Phillips screwdriver. For really stubborn screws, this method in combination with a vise grips simultaneously will usually work. Metric Allen head screws make a good replacement.
                07 Triumph Tiger 1050
