Bike dies after short run
  • mmtsquid
    • Aug 2010
    • 7
    Hello, new member here.
    A friend of mine just purchased a 1980 XS11 special as his first bike (yikes!).
    It was a non runner that he got for $500.
    While the bike sits in my garage, I've loaned him my CB550 to learn and take his test on.
    So, the gas tank is in pretty rough shape - I've removed and rebuilt the petcocks (one was leaky), and given the tank the POR15 treatment. Also pulled the carbs (they were nasty!) and replaced the bowl gaskets. Compression is within spec. and the same on all 4 cylinders.
    New plugs, gas, oil, and voila! She started right up!
    Took it down the road, and it started wanting to die at idle - by the time I got it back, it just rolled into the driveway and died. 10 minutes later, it fires back up. This time, I set a box fan in front of the bike and just let it idle for 15 minutes - no problems. Tried another test drive, same issue - about 1 mile then wants to die, and eventually does.
    Carbs are spotless (I've learned this lesson the hard way), gas is clean and tank flows fuel freely (I pulled the tank back off and opened the valves - flows like a river).
    Any ideas?
    First thing that comes to mind is the vent in the gas cap. Try riding with the cap unlocked and see what happens.
    • mmtsquid
      • Aug 2010
      • 7
      Hadnt even considered that - THX!
        When it is working on dying, check for one or two cylinders not up to the same temperature as the others. Spritzing a bit of water on each one will probably point out one or two "dead" ones, and the number oif dead ones and which ones they are will further pinpoint the problem.
        If I was placing a bet, I'd say you get two cool pipes, and they are paired 1-3 or 2-4.
        JAT...
        • ManagerMike
          • Mar 2010
          • 445
          • S.E. Michigan
          Just a thought, the fuel valves (needle and seat assemblies) on my 78 have filter screens on the inlet side. If your subject has them as well, they may be clogged, and that would explain idling fine but starving for fuel at operating loads.
          '78 E "Stormbringer"
          • mmtsquid
            • Aug 2010
            • 7
            I think I've discovered the problem - the fuel lines from the tank run into what appears to be a mechanical fuel pump of sorts, with a diaphragm inside ( I wondered where that part from the petcock rebuild kit went!). Took it apart, and it was all gunked up. Installed new diaphragm - will test this evening, but I'm sure this is a contributing factor.
              I am guessing your talking about the "Octy". It is a vacuum shut off for the fuel. And just to be sure there should be one vacuum line that runs to one of the carb intake boots. Usually the #2 carb boot but it really does not matter. Make sure it DOES NOT connect to the #2 carb BODY, the vacuum advance should be connected there.
              • mmtsquid
                • Aug 2010
                • 7
                I can see that it is operated by vacuum ( and the line is connected to the #2 carb boot), but what does it do?
                  It uses the engine vacuum to open up a diaphragm inside itself that allows the fuel to flow from the petcocks to the carbs. So then when the engine is operating, fuel should in theory flow to the carbs. When the engine is not running fuel will in theory not be able to flow to the carbs. The octy seems to fail frequently (thirty years will do that to it though) rebuild kits are available and some people hate the things and some people love the things. You can easily remove it and then just run the fuel lines straight to the carbs (with a filter in between, should put a filter before the octy if you keep it anyways).
                  • mmtsquid
                    • Aug 2010
                    • 7
                    Bike runs great!
                    Rode it 40 miles into work this morning, no engine problems.
                    However, the clutch is slipping - not sure if it needs adjustment, or a new clutch.
                      Bike runs great!
                      Try adjusting it first before you put money into it. check the tech tip for the procedure for adjusting it.
                      • mmtsquid
                        • Aug 2010
                        • 7
                        Yup, just needed adjustment.
                        Jeez, this thing is pretty quick! I will hate to give this back to my bud.....
                          You'll just have to get one of your own! Plenty of them for sale lately!
                          • mmtsquid
                            • Aug 2010
                            • 7
                            Yeah, as much as I hate to I think I'll sell my cb550. She's a great bike and my first love, but it's time to move on.
                            I noticed that this bike has an aftermarket oil cooler - and during lunch, another friend tried out the XS (he has a 78 xs11) and swears that this bike must have been bored out a bit as it feels a good bit quicker than his.
                            Was there any substantial difference between 78 and 80?
                            And do people actually try to make these things faster?
                              78 was the quickest and most powerful of them all. They started getting more environmental restrictions after that and started tuning them down.
