TOP DEAD CENTRE,,,,,,my take
  • Steptoe
    • 175
    • Thabeban,Bundaberg QLD , Australia
    have been trying for some time how to find definite tdc on my motor,, after the "professionals" got it seriously wrong,, , cost me a head, ,,, they were close to 10 degrees out
    eeinee way this is my take on pre-pulling a motor down,, just in case the pointer moves
    is now in my xs11 tool draw in my tool chest
    never ride faster than your gaurdian angel
    can fly
    1981 rh 5N5
    MIDNIGHTSPECIAL
    1188cc
    4 into 1 pipes with a transac muffler,
    as the motorcycling gods intended everything else stock std
    http://s856.photobucket.com/home/steptoexs11
    http://steptoexs11.webs.com/
    http://www.youtube.com/my_videos?feature=mhum
    1982 vf750 sabre
  • yamtom
    • 275
    • Midland Michigan
    great video izatta RH ?
    Hi,
    Nice video, nice RH too. What is that bar thats this side of the number one pipe with the rubber covering the end. Is that half of something to simulate a centerstand?
    Bikes Now.
    80 MNS 11 pods,georgefix kit,stock jets, HD Sporty muffs
    79 XS 11 Special, Emgo pods, stock jets, with Pacifico fairing, hard bags, intact stock pipes Sold
    83 Yammi Venture with custom footboards, 20k miles.
    83 Yammi Venture parts bike
    99 Valkyrie shield and bags 37k miles like new
    08 ZX 14 Kawa Ninja 6k miles Sold
      Hey Steptoe,
      I think I may have missed a bit of it or something. What is seems your finding is where the piston peaks in its travel. TDC is actually a few degrees of travel past that point. There is a certainamount of crank rotation where the piston is sitting still at the top of the stroke, maybe 5 degrees give or take. So finding the point where the piston tops out on travel is only part of finding TDC.
      If you put a degree wheel on the timing plate, with a pointer mounted to any stationary part of the bike and pointing to a spot on your degree wheel. You can turn the crank to the point you hit the top of piston travel, and mark that spot where the pointer is at on the degree wheel. Then continue turning the crank until the piston begins moving down, at the point the piston JUST begins to move down, mark that point as well. Half way between those two marks is true TDC, and THAT is where the pointer should be on the T mark of the timing plate.
      • tarzan
        • 1700
        • Chandler,Az.
        I agree, that isn't top dead center.But it will get you close enough to set valve timing with the crank.That is what they are aiming for, right?
        80 SG XS1100
        14 Victory Cross Country
        • dbeardslee
          • 4385
          • Maineville, OH
          Interesting video, but it seems like a lot of trouble to go through to find TDC. I just stick a dial gauge down into the spark plug hole and set the piston half way between where it stops moving up and where it starts moving down. I do this with the degree wheel already attached, and then bend my pointer a bit to point directly at TDC. Takes about 2 minutes. My $.02
            • 8753
            +1, same here.
            • Steptoe
              • 175
              you guy's are right as usual,, wrong terminology
              the bar on the engine protect bar is an unfinished cruising peg,,
              can fly
              1981 rh 5N5
              MIDNIGHTSPECIAL
              1188cc
              1982 vf750 sabre
                Nothing to be sorry about. Alot of work went into that bit, and you made a nice vid of it all to. It is a good solid way to help find the top of piston travel. Which is important in finding TDC.
                  - - - I just stick a dial gauge down into the spark plug hole and set the piston half way between where it stops moving up and where it starts moving down. - - -
                  Hi dbeardslee,
                  lacking a dial gauge, I use a pencil and judge by feel. Thing is, in the top ~10º there's not much difference in feel or in measurement so yeah, you gotta guess at the middle of the "no difference" zone.
