MegaSquirt has go leaps and bounds (IMHO) recently with MS Studio's VE Analyze Live which actually adjusts your tables as you ride to reach your specified AFR's. It has been a great couple of days on Megathrust. Today I decided to check my mileage. So, I topped off (paying careful attention to the 'full' fuel level, and went for a run down the highway. Hwy 101 is no Minot, SD. It's got plenty of turns, hills, and so forth. I tried to keep it between 60-65 +/- a few here and there. I also exited once, stopped, and got back on the highway all while trying to be pretty light on the throttle (no easy task for me ). When I finally got of at a town with gas, the tripometer said I had gone 51 miles since I topped off. When I topped off this time, the pump read 1.006 Gallons! EFI...having your cake and eating it too!
EFI Amazement!
EFI Amazement!
Sep. 12th 2015
RIPTags: None
Man, that might be worth the switch to fuel injection!-- Scott
Originally posted by Ken Talbot View PostHave you tried it out with this setup when you're giving it lots of hard twists and "bug 2.0" sort of speeds. It would be interesting to hear how it stacks up performance-wise.
I just spent 15 minutes trying to figure out how to post my Picasa slideshow of the pics I took but no luck. I think it can be done because my buddy posts his in his Chevelle forum.Last edited by 81xsproject; 08-20-2010, 06:46 AM.'81 XS1100 SH
Sep. 12th 2015
RIP
Is it really enough improvement to warrant the cost, or is it just for fun?1980 XS1100LG Midnight
1991 Honda CBR1000F Hurricane
A cold beer and another one!
Originally posted by XS1100 Newbie View PostIs it really enough improvement to warrant the cost, or is it just for fun?1980 XS850SG - Sold
I'd say if you can consistantly get upper 30 mpg range while being heavy handed on these machines, your doing REALLY good. When I get in playful mode, my mpg drops to low, low 30s. like 30-32. I avg 36 with alot of highway miles. If all highway, no fun miles I have gotten into the 40 range.
So, depending on how much the FI system cost, and the price your paying for fuel in your part of the world, just for fun could mean the fun you get to have with the fuel cost savings.Life is what happens while your planning everything else!
If I had to guess and hypothesize , had I not stopped and been driving on a straighter, flatter road, I could have gotten up around 55. And, yes, I EFI'ed for fun and learning. I haven't YET (but I am confident I will) squeezed any more WOT power out of it than my carbs made. However, the motor runs unbelievable smooth, I have low end power I could never get with my carbs, I don't ever have to remove ANYTHING to change tuning, and I have a fully programmable timing curve. My only dependability issues have been brought on by mistakes I have made during the actual process of tuning. From my best recount of parts and what I paid, I am into the FI for around $700. However, I sold my carbs for around half that.'81 XS1100 SH
Sep. 12th 2015
RIP
That sounds like good fun, and it ends up with little cost. The last hot rod i built was a couple bucks more than that. Probably 10 times that. At least you are not sacrificing mileage to get better performance, and hopefully reliability is ok.1980 XS1100LG Midnight
Originally posted by 81xsproject View Post...I haven't YET (but I am confident I will) squeezed any more WOT power out of it than my carbs made. However, the motor runs unbelievable smooth, I have low end power I could never get with my carbs, I don't ever have to remove ANYTHING to change tuning, and I have a fully programmable timing curve. My only dependability issues have been brought on by mistakes I have made during the actual process of tuning. From my best recount of parts and what I paid, I am into the FI for around $700. However, I sold my carbs for around half that.
With the issues of bad carbs/ignition parts (that will only get worse as the parts supply continues to dry up), this is a very viable alternative...Fast, Cheap, Reliable... Pick any two
Originally posted by crazy steve View PostFrom what I can tell, the MSII you're using is batch-fire injection, so there should be more gains with using a sequential-injection MSIII controller (of course, probably more $$! ).
As far as WOT, I don't think the FI can do too much more. The real gain offered to the XS by MS is the programmable timing curve. From my recent reading, the potential to really squeeze out hidden power is in the ignition timing. The problem is that the only real way to tune for optimal timing is on a steady state dyno ($$).Last edited by 81xsproject; 08-20-2010, 02:03 PM.'81 XS1100 SH
Sep. 12th 2015
RIP
I would think that the only major benefit of sequential EFI would be an increase in fuel mileage, and it may not be that much. Does the MSII fire all the injectors with each plug fire, or are they 'paired' to the coils? If the latter, I doubt if you would see much gain. And I'm sure it would be a pain to get a cam positioner in there.
As to timing, yeah, that's where the real 'fine tuning' takes place. Out of curiosity, does the MS accept external inputs for altering the timing with multiple curves? If so, there's probably a bunch of mileage to be had with a 'vacuum switch' to change curves under light loads, using manifold vacuum as the source. This would be the same deal as the ignition on the XJ. Harley uses the same deal, but uses a stand-alone switch rather than having it built-in to the box. Theirs can be adjusted too, with roughly a 4 to 10 "hg range.
Maybe you could have the first 60+ mpg XS11!Fast, Cheap, Reliable... Pick any two
Originally posted by 81xsproject View PostMegaSquirt has go leaps and bounds (IMHO) recently with MS Studio's VE Analyze Live which actually adjusts your tables as you ride to reach your specified AFR's. It has been a great couple of days on Megathrust. Today I decided to check my mileage. So, I topped off (paying careful attention to the 'full' fuel level, and went for a run down the highway. Hwy 101 is no Minot, SD. It's got plenty of turns, hills, and so forth. I tried to keep it between 60-65 +/- a few here and there. I also exited once, stopped, and got back on the highway all while trying to be pretty light on the throttle (no easy task for me ). When I finally got of at a town with gas, the tripometer said I had gone 51 miles since I topped off. When I topped off this time, the pump read 1.006 Gallons! EFI...having your cake and eating it too!1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
Originally posted by XS1100_OEM4ME View PostHow much does it cost to change to EFI
From my best recount of parts and what I paid, I am into the FI for around $700. However, I sold my carbs for around half that.Life is what happens while your planning everything else!
Originally posted by crazy steve View PostI would think that the only major benefit of sequential EFI would be an increase in fuel mileage, and it may not be that much. Does the MSII fire all the injectors with each plug fire, or are they 'paired' to the coils? If the latter, I doubt if you would see much gain. And I'm sure it would be a pain to get a cam positioner in there.
Originally posted by crazy steve View PostAs to timing, yeah, that's where the real 'fine tuning' takes place. Out of curiosity, does the MS accept external inputs for altering the timing with multiple curves? If so, there's probably a bunch of mileage to be had with a 'vacuum switch' to change curves under light loads, using manifold vacuum as the source. This would be the same deal as the ignition on the XJ. Harley uses the same deal, but uses a stand-alone switch rather than having it built-in to the box. Theirs can be adjusted too, with roughly a 4 to 10 "hg range.
Maybe you could have the first 60+ mpg XS11!Last edited by 81xsproject; 08-21-2010, 08:40 AM.'81 XS1100 SH
Sep. 12th 2015
RIP
