Trouble starting
  • GTXS1100
    • Jun 2010
    • 224
    • Columbia MO
    Trouble starting
    I have been haveing problems with my bike not starting unless i unplug the two wire conector on the generator. It will start and run fine when i unplug it and if i plug it back in it will load the engin and it will die. It seams to crank real slow if its pluged in. i put a different generator on it and it seamed to be alright for a wile then the next day it acted the same way. plz let me know if any one esl has had this problem before. Thank
    80 XS1100G Black Betty (Daily Driver)
    79 XS1100SF (Buddys Project)
    82 XJ750 Maxim (Fathers Bike)
    81 CB750F SS (Buddys Project)
    06 GSX600F Sold! (Was Mine)
    81 XS1100 Failed Bobber Project (Mine)
    81 XS1100 Parts (Mine)
    Grip it, Rip it, and Stick it!!!
    Sounds like you've got a short somewhere on that circuit! Time to take ALL the connections apart and clean them.
    • GTXS1100
      • Jun 2010
      • 224
      • Columbia MO
      that sound too simple to be my problem my luck is never that good but ill try it and see hope thats it! thanks
        Hey GT,
        You've got me a little confused? The "ALTERNATOR" has 3 white plugs that connect it to the harness behind the fuseblock. SO...what 2 wire connector are you talking about?
        Several questions. How old is your battery? Have you done a charging test with a voltmeter with the engine running/idling and again at 2500+ rpm?
        With a dead/dying battery, it could cause enough of a drain as well as NOT power the charging system properly, and when the volts drop below ~10.5 volts, the TCI will not work, engine dies!
        So...a more thorough testing of your charging system is in order.
        • smitty57chevy
          Xsive
          • Aug 2010
          • 13
          • 3rd planet from the sun
          The two-wire connector is the field coil. They draw alot of current, so TC is onto something. I'd take a hard look at the condition of the battery.
          • GTXS1100
            • Jun 2010
            • 224
            • Columbia MO
            the only thing about that is i took it all off my bike that i had running and every thing worked just fine on it so im going to look in to seeing if any of my wires are chafed or touching somewhere
            • GTXS1100
              • Jun 2010
              • 224
              • Columbia MO
              My "alternator" only has 2 conectors one is a three or four wire conector and the other one is a two wire conector i think the other conector is for the pick up coil on the distributor i think i may be totaly wrong but thats how i think it goes and my bike is an 81 standard i think im not sure.
                The two wire connector, brown and dark green, are the field coil wires for the alternator. The 4 wire connector, 3 white and 1 yellow is the alternator voltage output. Yes, there is a similar connector nearby behind the fuse panel, that is the pick up coil wire connector.
                • smitty57chevy
                  Xsive
                  • Aug 2010
                  • 13
                  I must be typing in invisible ink.
                  • GTXS1100
                    • Jun 2010
                    • 224
                    • Columbia MO
                    haha your not i was just trying to explain it better but im going to check the battery when i get home thanks
