Cam replacement: Stupid is as stupid does...
  • clcorbin
    • Jan 2010
    • 495
    • Albuquerque, NM
    Sigh.
    I pulled the head off this week to address a couple of problems (oil leak at head gasket and worn valve stem seals, replace the intake carb boots). All went well. Not the first time I've had this bike apart and it went fairly easy.
    Problem was, once I got it back together, it wouldn't start! It turned over fine and all cylinders were firing, but it wouldn't fire up. After messing with it a while, I decide to try the other method: walk away and let my brain think about it a while.
    Unfortunately, once it had peculated through the gray matter, I DID figure out the problem: I reinstalled the bloody cams with the crank at the C mark instead of TDC! What an IDIOT!
    I've decided to call it a night for now. Tomorrow, I'll tear it apart and see if I damaged any valves. From the notes in the manual, I have got to be RIGHT at the limit on how far out the valves can be before things start to hit. On the bright side, everything FELT smooth when I was first turned it over by hand, so maybe... Otherwise, it looks like I will be ordering a set of valves from Geezer after all!
    What an idiot...
    -- Clint
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Hey
    Originally posted by clcorbin
    Sigh.
    What an idiot...
    Hey, the good news is it didnt fire, just turned over. If you had big valve clearance problems you should have felt/heard it when turning over by hand. Good luck, hope all works well for you and your bike
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    • TADracer
      • 1417
      • Kenner, Louisiana USA
      Chances are your valves are OK. If you had the cam dots lines up while the crank was on the 'C' mark then the valves are still in correct relation to each other, just not the pistons. You retarded the cam tining by 45 degrees and thats why the motor would not start.
      If one of the valves was contacting a piston, you would most likely feel it.
      So, if you did not feel a definate hang-up turning the crank by hand to check the cam alignment then you are probably OK.
      Mike Giroir
      79 XS-1100 Special
      • clcorbin
        • Jan 2010
        • 495
        • Albuquerque, NM
        Well, it appears all is well with the valves. I got things timed correctly this morning and it fired right up. No strange noises, no additional ticking from the valves (has anyone actually heard an XS11 that DIDN'T make SOME noise from the valve train?).
        This weekend, I'll run the valves and resync it and get it out on the road. For now, I need to hit the road myself, so it will have to sit in the shop for a few days.
        -- Clint
        • Poprock
          • Apr 2005
          • 594
          • Oregon Coast
          I'm happy for you that the valves are OK. I know they're easy to bend. OTOH, Geezer's valves are way good and his intakes provide a low end boost that has to be experienced to believe. And...his prices are way right!
          • clcorbin
            • Jan 2010
            • 495
            • Albuquerque, NM
            I was actually kind of looking forward to that! Unfortunately, there just isn't any way I can justify the valves unless I have to have the valves. But at the rate I am going through my "spare" valves, I'll be ordering a set before I know it!
            Let's see:
            1) timing chain broke and took out three valves (2 exhaust, 1 intake)
            2) While reassembling, during an ill thought out bench shimming session, I managed to take out on more exhaust valve!
            3) While disassembling from head gasket and valve stem seal refresh, I managed to take out an exhaust valve when I rotated the crank to get to the last bolt on the intake cam without remembering that I had ALREADY removed BOTH bolts on the exhaust cam gear!
            I'm learning, but items 2 and 3 make me feel VERY stupid!
            -- Clint
