Tweaking Carbs
  • barrelguy
    • 169
    • Oliver, BC
    Tweaking Carbs
    I'm just about to install a set of 4-2 Jardines on my 80 xs11g. I've seen various info and heard some mutterings about needing to re-balance, re-jet, re-whatever my carbs. Any truth to this or just a bunch of smoke & mirrors?
    Anybody really know what time it is?
    1980 XS 1100 Special
    Mostly stock & original
    Added Yamaha fairing (w/ 8-track!)
    Torpedo bags
    New paint (still) pending
    Stainless brake lines
    Tkat forkbrace
    Coils from Honda 1000
    Previous bikes:
    1968(?) 350 Harley Davidson
    1977 Yamaha 650
  • petejw
    • 2269
    • sydney australia
    the stock bikes came with a dual exhaust,
    so unless theres any mods to the intake,
    you should be sweet to go.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
      The different exhaust will flow different so you should at least resync the carbs after you put them on. You may or may not have to rejet the carbs only time will really tell. Each bike reacts differently to changes. For now though you would be fine just putting the new pipes on and sync the carbs and go for it. Check your plugs every now and then and see how the jetting looks and you should be fine.
        • 3186
        When the Jardine spaghetti 4 into 2 were installed on my 79SF I had to
        richen the idle/air screws a bit and re-synch but no jetting changes were made.
        • barrelguy
          • 169
          • Oliver, BC
          Thanks for the info - I'll let you know how things work. Discovered this weekend that I need to replace all the studs with longer ones to make this work. A day with some penetrating oil should see this through.
          Torpedo bags
          Tkat forkbrace
          Previous bikes:
          1977 Yamaha 650
