How many '80 & '81 MNS's were made?
  • Bikerbear
    • Jun 2009
    • 21
    • Lyon Co. Nevada USA
    Does anyone know or have any idea how many XS1100 MNS's were made?
    1980 XS1100G = Current Project - 1980 XS1100LG = Dormant
    Welcome to the forum! Your question is one that has been asked by many folks here, and though information floating around the 'net says that only 250 were made each of the 2 years, the Serial numbers that have been collected here almost undeniably make that impossible. It's obvious they were made in limited numbers, but definitely in the thousands.
    • Bikerbear
      • Jun 2009
      • 21
      Thanks for your reply. I tried to edit my post to include an introduction but it didn't work? So I will post an introduction after this reply. Anyway thousands sounds more like the actual figure. Is there a registry somewhere to log mine in?
        There was a thread here a while back where people were entering their Serial Numbers. Not really a "registry" persay, but it showed that the numbers went much higher than 250 for each year. You might be able to locate the thread with some searching if you want to.
          • 3189
          There is the one on this page http://micapeak.com/reg/view2/XS11/all/1/75/YYYYYYY/
          there may be others but this is the only one I am aware of.
            Serial numbers on 'special edition' models usually don't mean much unless they were all built in a continous 'batch', which is rarely the case; they're generally mixed in with 'standard' models. The only way to be sure is if the model has a separate 'special' number, such as a plaque.
            As to value, 'cosmetic' or 'trim' upgrades are seldom worth more than about $50-100 over their more common brothers if both are in the same condition, and if any of the special parts/trim are missing, the value will be about the same. There's always the exception if you find the right buyer, but buying as an 'investment' won't pay as a rule. If the 'upgrades' were performance items, then you have a much better chance of seeing appreciation...
