Currious
What you are doing looks great so far.
I'm really interested to see how this paint holds up. I have used rustoleum before with mixed results but never used the paints you are using. Just as with using water on bondo I have had rustoleum loose bond with paint after being covered. Typically with rustoleum like with bondo I like to go to bare metal or apply over an etching primer. The issue is that any porus material can absorb moisture or hold vapors that react after they are sealed. I'll be checking back in the future as I'm always willing to learn new things expecially when I can avoid stripping. Spraying requires a good enviroment not always availiable. There is always overspray. Even if the tempeture is right and no dust them bugs will fly from Florida to Alaska in winter and eat thew concrete to get into spray paint. My bike looked much worse from sitting in a damp shed than yours does sitting out so I am sure it will look great.
