I finally brought my bike home from it's long WI vacation.  I am now trying to get her back together.
To install the Accel coils I studied Gareth's instructions and great photo gallery (see links below). The pull that he used has been discontinued, and I could not find anything similar. So I altered some "L" brackets to clear the rivets on the coils. However, I am having serious clearance issues. Do I need to relocate the horn? It also seems to fit better if I lower the front and use the original location for the rear. Has anyone done it this way? Can I just drill a hole through the mounting on the coil, or should I grind it out like the pictures show? Can I reverse the coil wires and use the red 90 deg. caps at the coil, and either use the straight caps at the plug end or purchase some new 90 deg. caps. With the straight caps the wire comes out of the cap virtually on the valve cover. It is far to tight to get it to bend past the valve cover without touching it.
Sorry for being so long winded, and thanks in advance for the help
