16" wheel on a standard
  • cowboybob998
    • Mar 2009
    • 371
    • KC MO
    How hard is it to put a 16" wheel on a standard, got a 16" wheel with a good tire on it and need new tire and dont want to spend the money, doing the final drive swap and figured it was a good time to do it all at the same time.
    1979 xs1100 f
    142 main, 45 pilot, Jardeen crosover 4/2, no air box
    floats @ 25.7
    1979 xs1100 F
    1978 gl 1000 goldwing
    1981 gl 1100 goldwing
    !986 venture royale 1300
    Just an ol long haired country boy, come to town to spend some egg money
    when ya get bucked off, get back on
    Swapping the standard 17" wheel with a 16" wheel is a little more complicated than just swapping the wheels.
    The two models use a different method for spacing the wheel in the swingarm. So, you need the combination spacer and bearing cover from the special along with the bracket for stiffening spacing and positioning the caliper mount from the special model. The parts can be found.
    • Incubus
      • 1003
      • Austin TX
      Here is a picture of the stock setup on Succubus, my first XS11F with the stock 17-inch wheel:
      Here is the setup on Incubus, my other XS11F which is fitted with a 16-inch wheel from a XS11SF. The caliper bracket is from a Standard. I couldn't make the Special bracket fit.
      The spacer that makes the 16-inch fit is not stock to either model. It is a custom part. I was lucky to find it on one of my parts bikes.
      Patrick
      XS11F (Incubus, daily rider)
      1969 Yamaha DT1B
      • perurider
        • Apr 2010
        • 121
        • Peru, Indiana
        BUY A TIRE!!! Do a search of the threads...youll see it is soooo not as easy as it would seem. IMHO, of course.
        '79 XS 1100F
          Also, just another point of thought, you're doing the FD mod to get lower engine rpms, but putting on the smaller 16" wheel will offset some of the gains you would be getting with the FD mod!
            The big difference between the two wheels as far as fit is the 'Special' wheel has the brake rotor moved .300" out from center compared to the 'standard'. So that explains the thicker spacer; the brake caliper/caliper mount are the same, but the steel torque bracket is shaped differently because the caliper is further out. Using 'other' parts can lead to misalignment of the caliper, so be careful if doing that.
            '78E original owner
            • cowboybob998
              • Mar 2009
              • 371
              • KC MO
              Spare parts
              I have spare parts off of a 1980 special that was wrecked, i bought it for the motor, what I was wondering if the special parts would just change over to the standard, as much as I have to do on all the half done projects that i have started it may be better to just buy the new 17" tire
              I have about four running bikes that I need to do something to all of them, should sell at least two of them
              thanks, I love this place
              1979 xs1100 f
              floats @ 25.7
              1979 xs1100 F
                If you have the whole 'special' bike, you have everything you need to swap wheels. Use the 16" wheel, the thicker (by .3") 'special' spacer, and the 'special' steel caliper bracket. The standard has an additional spacer between the two caliper brackets; don't use that. With these parts it's a bolt-on...
                '78E original owner
                • SFSPECBIKER79
                  • Jul 2008
                  • 403
                  • NC
                  rear wheel swap
                  just thinking about it. does the std. transmission have identical gears as the special. if so, then when you change the std. to special wheel, it would make your std. start off quicker from a stand still. i have both std. and special bikes, but never noticed any difference in how each one started off from dead stop. i never been into the transmission. does any one know what the difference is in the to. if any. thanks
                  79 xs 1100 spec & 80 xs 1100 g
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    • Fort Myers, Florida
                    change
                    It can be done. the indent on the special is set for the smaller wheel die. If your are not trying to change RPM and other things at speed, buy the right tire and save the work
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                    • rover
                      • Jan 2004
                      • 765
                      • central WI (715)
                      wheel
                      One thing most of you have overlooked. The side stand will have to be changed, or you may park the bike and find it on it's side when you return. The spec stand is a bit shorter. Also, the center stands are different, but will interchange. It is quite difficult for me to get my Std up on the center. With a 16" wheel, I don't think I could do it. The stands interchange quite easily, tho.
                      79 F (Blueballs)
                      79 SF (Redbutt)
                      81 LH (organ donor)
                      76 CB 750 (gone to MC heaven)
                      rover has spoken
                      • XS1100_OEM4ME
                        • Mar 2009
                        • 1619
                        Stand
                        It will still be standing if you turn the front wheel all the way to the right, as to the center stand change, you will need to move the stop on the exaust if you make this change.
                        1980 XS1100 Special
                        1990 V Max
                        1982 KZ750 LTD Twin
                        1974 CB750-Four
                        Past/pres Car's
                          I don't think you need to change the stands; the size differences in the tires isn't that great. If you check the specified diameters of the various tires that fit these bikes, you'll find that the tires only vary about 1" at the most, even between the 16" and 17". A Dunlop 404 130/90-17 shows as 25.97", while a 404 130/90-16 is 25.16". But if you go to a Elite 3, now the 130/90-16 is 25.70". In any case, that will change the rear height of the bike no more than a 1/2", usually much less. A smaller tire will put the bike a bit more vertical on the side stand, probably making it less prone to going over.
                          I will note that tires have 'shrunk' since this bike came out; when the XS was new, tires were sized in inches (4.50H-17, etc) but when they converted to numeric (130) the diameters got smaller. An old worn 4.50H-17 I have measures out at nearly 26.5" and must have been nearly 27" when new.
                          And even when new (with the 'proper' size tire), these took some grunting get it up on the center stand...
                          '78E original owner
