dumb question 750/850 swap
  • cowboybob998
    • Mar 2009
    • 371
    • KC MO
    Dumb question, reading the art. that top cat done on the final gear swap and can not figure out witch shaft to use 850 or 1100, I woulld think the 1100 because of the lenth of the swing arm ?
    Got a final drive off of ebay for 36 bucks shiping and all, off of 1980 850 special
    Any help is wellcome
    1979 xs1100 f
    142 main, 45 pilot, Jardeen crosover 4/2, no air box
    floats @ 25.7
    1979 xs1100 F
    1978 gl 1000 goldwing
    1981 gl 1100 goldwing
    !986 venture royale 1300
    Just an ol long haired country boy, come to town to spend some egg money
    when ya get bucked off, get back on
  • XJOK2PLAY
    • 2099
    • Skiatook, Ok.
    Yes, Sir... use the 11 shaft.
    2011 Kaw Concours 14 ABS
    • cowboybob998
      • Mar 2009
      • 371
      • KC MO
      Thanks, the more I think about it, that makes sence.
      have you known people to have trouble getting the fill plug out of these, this one looks like someone had trouble at one time and used a chizel on it, hope it comes out ok.
      1979 xs1100 f
      floats @ 25.7
      1979 xs1100 F
        Originally posted by cowboybob998
        - - - have you known people to have trouble getting the fill plug out of these, this one looks like someone had trouble at one time and used a chizel on it, hope it comes out ok.
        Hi Bob,
        the final drive and middle drive filler plugs are hard to get out because they have small Allen key sockets in them and on the bike you can't shove straight down on the Allen key and reef on it. Yours is on the bench so you can get at it with an Allen key socket and it should come out OK.
        To put off future trouble, what I did was to file the filler plug's top smooth and braze a hex nut on top of it so it can be turned with a wrench. Others have swapped in a second drain plug as a filler plug. Seems they are the same thread and have a hexagon to turn them.
        • cowboybob998
          • Mar 2009
          • 371
          • KC MO
          Hi Bob,
          Sounds like a good idea to me, take the one out of the 1100 final drive (drain plug) and use it.
          Now if I can get all this done so i can ride it, have coils to swap out and sync the carbs yet, i am slow about getting things done, sence i have another bike to ride, hard to stay off of it to get outher thing done
          1979 xs1100 f
          floats @ 25.7
          1979 xs1100 F
            When I got it, mine had the filler plug replaced with a regular metric oil drain plug, with a nice big head on it. Much easier to remove than the allen plug.
            I'll be doing the FD swap here soon too, and I will definitely be moving this filler plug into the 850 FD I got.
