Will a 1979 XS1100 tranny fit in a 1980 XS1100 Special?
  • jshepard935
    • Jun 2010
    • 26
    I found a transmission I want for my bike that appears to be in good shape and I just want to get it while it's on the market. This transmission is listed under 79 XS1100, and mine is a 1980 XS1100 Special. I figure the engines are no different so it should be fine, but I just want to be sure. My transmission grinds a little bit when I shift to 4th gear and has had 2 false neutrals in the last couple of months, so I want to grab this tranny now.
  • Lamric
    XStremely XSive(Deceased)
    • 410
    • Kenley, Surrey, England
    All the parts on the Transmission microfiche for the 1979 'F' model are the same for the 1980 SG model - go ahead
    Brian
    XS1100 LG "Mr T", SG "ICBM" & FJ1200
    Check out the XS Part Number Finder
    Be not stingy in what costs nothing as courtesy, counsel and countenance.
    • jshepard935
      • Jun 2010
      • 26
      Thank you. So pretty much all XS1100s are mechanically the same?
      • tinman905
        • Aug 2007
        • 946
        • Orangeville,Ontario ,Canada
        They are basically the same 78 to 79 in 80 Yamaha changed the size of the valves in the head and also changed the carbs in 80 too.
        BDF Special
